bleeding brakes!
Results 1 to 5 of 5
    Rods 'n' Sods Junkie Dean's Avatar
    May 2010
    horsham sussex
    154
    15
    Dean is offline
    bleeding brakes!
    advice please,need to flush through and bleed brakes that have been standing for four years, have fitted new pads, do i need 4 gallons of brake fluid or is there something i can flush through and then use new fluid? any advice welcome,cheers.
    Official RnS Addict Zody's Avatar
    Sussex
    1,769
    Zody is offline
    The proper way would be to remove the Callipers & wheel cylinders, then
    check the movements of each one, even replace the seals, also check brake
    lines, and flexy pipes for wear...and then bleed the system....can't be to careful
    when it comes to stopping power
    The car is open, the keys are under the dog !
    Official RnS Addict rockhouse's Avatar
    Dec 2010
    clacton-on-sea
    918
    54
    rockhouse is offline
    just use new brake fluid depends on what it is you wont use 4 gallons
    May 2010
    horsham sussex
    154
    15
    Dean is offline
    hi zody, thanks for info,the rear calliper is new and the front is in good working order, i just want to be sure of not leaving any of the old fluid in the system when i replace it with new. manythanks Dean.
    Quote Originally Posted by Zody View Post
    May 2010
    horsham sussex
    154
    15
    Dean is offline
    Quote Originally Posted by rockhouse View Post
    hi rockhouse, i was not sure how much fluid it would take to flush the system through until i was sure it was clean, and then have to get rid of it, seemed a waste of fluid. i thought there might be something else i could use. many thanks Dean.
    1. '65 Thunderbird front hubs and brakes
      By 30psi in forum Stuff - WANTED
      Last Post: 16-07-2009, 14:39
    2. A brakes, spindles, old grillshell, wire wheels
      By originals in forum Stuff - FOR SALE
      Last Post: 11-07-2009, 18:06
    3. Brakes and speedo mot Q's
      Last Post: 08-07-2009, 13:17
    4. wilson weld brakes buick drums
      By 4potter in forum Stuff - FOR SALE
      Last Post: 16-05-2009, 23:47
