Bleeding brakes, having a nightmare
Results 1 to 10 of 19
    Rods 'n' Sods Junkie road rage's Avatar
    Dec 2011
    Wickford Essex
    242
    road rage is offline
    Any advice on this will be gratefully received, I have a 1977 Chevy C10 pick up, I have just fitted new front brake calipers which went fine, the problem is getting them up to pressure, I have been bleeding them for best part of the day and to start with i could get good pressure, but once i fired the engine up the pedal would go right to the floor.
    Several attempts later and still no pressure, I have been told by a very good local fella that I still have air in the system and i have no doubt that he is right, but does any one have any tricks to doing bleeding or is an easy bleed kit available for a chevy master cylinder as my GF has had enough of me saying hold down now pump etc lol.
    Thanks in advance
    Rob
    TechnicalTom
    Nov 2009
    CORK IRELAND
    396
    10
    TECHNICALTOM is offline
    Any chance of a few photos of the installed calipers, Just to help eliminate things the bleed nipples been on the bottom!!!! no disrespect here. Also the routing of the flexible hoses.A few tips I could suggest would be to reverse bleed the calipers, what I use is an old " squirty" type oil can ( very clean) and use some clear plastic pipe so you can see no air bubbles are been sent into the calipers,just fill the can with clean unused brake fluid of the correct spec s , DOT 4 or 5 ETC. then connect the tube/pipe to the loosened bleed nipple, repeat on the other side, put some rags around the master cylinder in case fluid overflows ,( the cap is off for this excersize ) just pump the ( oil can) lever gently 1/2 a dozen times should do , then lock the bleed nipple without removing the pipe .
    Some times I open both back bleed nipples ,then bleed the fronts , then bleed the backs. I have even seen some fellow mechanics ( Technicans nowadays) jack up the front of the vehicle whilst bleeding difficult stuff.
    Nov 2009
    Ol'fordshire
    2,933
    88
    JackGriffin is offline
    Did you just swap the calipers over without the master cylinder draining down? If not there could now be air in the m/cyl. and it could now need bench bleeding, or pressure bleeding. Have you got a factory service manual? I did have one for my old '79 but I'd have to have a hunt around to see if I still have it.
    23,198
    As above for starters . I also worked on a 77 Buick which refused to bleed. Turned out there was a pressure limiting type valve in the rear line and it had to be bled in a certain order for it to 'shuttle' to teh correct position to make them all work.
    Dec 2011
    Wickford Essex
    242
    Thanks for the replies gents, ok here we go with a bit more info, sorry no photos as yet coz i wrapped it all up for another day, the bleed nipples are on the top side of the caliper's and the calipers are marked left and right, taking it that the left is drivers side, I did not drain the master, I simply disconnected the flexi pipe replaced the calpiers then reconnected the pipes with new copper washers, then started to bleed, topping up the master as required.
    The flexi lines bolt up to the chassis and the fixed line is connected at that point, the flexi then runs along the wishbone and it is clamped about half way down the wishbone, then it connects to the calipers, I did one side at a time to insure that I has a pattern to follow should I not be paying attention lol.
    I was told that as the brakes are dual circuit that there is no need to bleed the rears, I was given dot 3 fluid buy the shop, they also supplied the calipers, I hope this gives a better picture, and I thank you for your help so far
    All the best
    Rob
    Nov 2009
    stourport
    5,529
    7
    beach57 is offline
    The rears still need bleeding also .
    Leicester
    5,696
    594
    bigyellataxi is offline
    Fueled by Jim and Luckies.
    Dec 2011
    Wickford Essex
    242
    Thanks paul67, I have just found my haynes manual and that says exactly that, so I will give that a try during the coming week and see what happens, but please if any one has anything else to add I am all ears, and thank you all for the help so far
    Official RnS Addict Slamera63's Avatar
    Feb 2010
    Hull, Yorkshire
    1,956
    Slamera63 is offline
    Bought one of these off Fleabay a while back, money well spent it makes brake bleeding a doddle especially when your by yourself.
    Sealey Car/Bike Brake/Clutch Fluid Vacuum Bleeder VS020 | eBay
    Jul 2011
    West Mersea
    3,106
    55
    Big Joe is online now
    I use the Gunson pressure bleeding gadget, works every time although the bottle is a bit small
    1. bleeding brakes
      By nobody in forum Tech Discussion
      Last Post: 21-01-2012, 23:04
    2. bleeding brakes!
      By Dean in forum Tech Discussion
      Last Post: 07-07-2011, 06:57
    3. A brakes, spindles, old grillshell, wire wheels
      By originals in forum Stuff - FOR SALE
      Last Post: 11-07-2009, 18:06
    4. Brakes and speedo mot Q's
      Last Post: 08-07-2009, 13:17
    5. wilson weld brakes buick drums
      By 4potter in forum Stuff - FOR SALE
      Last Post: 16-05-2009, 23:47
