Brake bleeding gm proportioning valve
Results 1 to 10 of 12
    24v
    Official RnS Addict 24v's Avatar
    Mar 2011
    Cork,Ireland
    631
    111
    24v is offline
    As above
    I have a gm brake proportioning valve and can't get any fluid from the rear calipers. All worked fine until I changed from drums to calipers. Master cylinder and rear calipers in good working order. Front calipers have fluid. But nothing from rear. Googled and searched how to reset the valve which has been working properly until I modified the reR system. but so far no luck
    Any advice would be great.
    Work to live don't live to work....
    V8 BMW powered 55 chevy pick up bagged
    Cummins powered ford f8 Big Job
    13,868
    the shuttle valve inside may have gone one way and need resetting
    24v
    Mar 2011
    Cork,Ireland
    631
    111
    24v is offline
    I think that's what has happened but have tried a few of the methods I have found on the net and still no fluid to the rear.
    Glasgow,Scotland
    2,123
    german8rcoupe is offline
    Do away with it now you have disc /disc.
    24v
    Mar 2011
    Cork,Ireland
    631
    111
    24v is offline
    Join the pipes and bypass it or a fit a manual proportioning valve?
    13,868
    just join the pipes to bypass it mate. if you have issues with rear wheels locking then add a proportioning valve then. no point spending the money if it doesn't need it. make sure you don't test it in heavy traffic though for obvious reasons
    24v
    Mar 2011
    Cork,Ireland
    631
    111
    24v is offline
    Thanks
    Will I join the front pipes also with a tee or are they ok?
    I will stay away from solid objects while testing also..
    13,868
    use a 't' for the front so the valve is totally removed.
    24v
    Mar 2011
    Cork,Ireland
    631
    111
    24v is offline
    Ok will do
    thanks
    24v
    Mar 2011
    Cork,Ireland
    631
    111
    24v is offline
    The local brake guy has metric only
    My pipe with a vernier is 11mm ouside roughly and the front for the T piece looks 8mm
    Is it imperial or unf thread on the chevy brake parts?
  1. Chevy Brake Proportioning Valve
    By Dr Strangelove in forum Stuff - FOR SALE
    Last Post: 18-09-2013, 00:38
  2. Recommend a brake bleeding kit tool thingy
    By zephyr in forum Tech Discussion
    Last Post: 01-02-2013, 23:22
  3. brake bleeding problem
    By wrench in forum Tech Discussion
    Last Post: 31-07-2012, 23:05
  4. Brake proportioning valve & M/C help required!
    By Marc in forum Tech Discussion
    Last Post: 21-09-2011, 11:38
  5. Brake bleeding issues
    Last Post: 21-06-2011, 12:14
