Brake bleeding issues
Results 1 to 10 of 16
    Jul 2009
    Yeovil, Somerset
    1,760
    816
    Stroprock is online now
    Having trouble bleeding brakes. I seem to have all the air out on all wheels, but the pedal still has loads of empty travel before it starts to slow the wheels, and it isn't effective enough either, slowing but not stopping the wheels. I have the pedal so in the un-pressed position, the MC is fully out. I was wondering if perhaps the rod isn't going in far enough, and I need to redesign the pedal. Or is more likely a problem of air still in the system?
    Official RnS Addict Bel Air Lugosi's Avatar
    Aug 2009
    Sunny Whitby
    1,779
    249
    Bel Air Lugosi is offline
    What brakes has it got? Are all the bleed nipples at the top? Air rises and if the pipes go in at the top, and your bleed nipples are at the bottom air gets trapped and you cant shift it.
    I had this happen on a volvo rear end. Worth checking.
    If its low n black n shiny n sparkley n loud n spitting fire....... It's probably mine.
    [email protected]
    www.whitbykustom.com
    http://www.facebook.com/whitbykustompaul
    west midlands
    2,799
    259
    stevie.t is offline
    if you pump the pedal dose it get any fimer? before you bleed the brake's did the master cylinder bottom out before the pedal hit the floor, are the brakes adjusted, what size m/c are you using ? is it disc/drum or disc/disc, or all drum,s? need mor imfo on what you have
    Jul 2009
    Yeovil, Somerset
    1,760
    816
    Sorry, its Triumph Spitfire front brakes and MC, and reliant rear brakes (drums). The brake master cylinder is 5/8" bore. It starts to go hard after 1/2" of movemment. The bleed nipples on the calipers (front) are on top. Yes, it gets firmer when you pump, so I guess that indicates air in the system still.
    Jul 2010
    liverpool
    320
    90
    jackzx10 is offline
    Assuming your master cylinder is above your cylinders/calipers gravity bleeding never seems to fail ..so its master cylinder top off then open the bleed nipples one at a time and let the fluid drain into a container for a few minutes (keep an eye on the m cylinder level ..top up with the fluid youve drained into a clean container) .go round all the nipples and jobs a good 'un.
    "Mr Fiddler" stevetoxic's Avatar
    Feb 2010
    Milton Keynes
    2,180
    24
    stevetoxic is offline
    I had a similar problem with my Chevy Truck...turned out I had'nt bled the master cylinder before I started on the brakes.
    just a thought.
    Nov 2009
    stourport
    5,524
    7
    beach57 is offline
    Have you the valve for the drums fitted in the master.
    Jul 2009
    Yeovil, Somerset
    1,760
    816
    Quote Originally Posted by paul67 View Post
    You mean the proportioning/combination valve?
    Lost in the ozone. . .... malc's Avatar
    Sep 2010
    Barcelona Spain
    3,029
    52
    malc is offline
    Quote Originally Posted by stevetoxic View Post
    just a thought.
    My first thought as well, the MC needs bleedin´.
    12,517
    mygasser is online now
    just a thought.
    i made that mistake once. i jammed the pedal down hard overnight and the air had risen back to the reservoir by the morning. saved taking it all apart to bleed the master then all the 4 corners again.
    1. Brake issues............. Still!
      By Bel Air Lugosi in forum Tech Discussion
      Last Post: 03-06-2011, 18:36
    2. Think we've got issues ...
      By Roadrunna in forum Chat
      Last Post: 04-05-2009, 20:42
    3. Mini heater. Brake servo.
      By Lee in forum Stuff - WANTED
      Last Post: 27-04-2009, 19:04
    4. 67 chevy 11 - Nova brake shoes
      By stevie.t in forum Stuff - WANTED
      Last Post: 27-04-2009, 18:43
