Brake booster convertion problems
Results 1 to 4 of 4
    Feb 2010
    STAFFORDSHIRE
    120
    36
    MOPARCRAIG is offline
    Fitted a master cylinder and booster off a toyota surf to my Charger.
    Bled all the air out of system, connected vacuum pipe from booster to outlet on intake manifold.
    Brakes work, but pedal fluctuates and brakes hold on at low revs, fitted a non return valve but hasnt made much difference.
    Should i fit a seperate vac can?
    ideas?
    Lower Kingswood, Surrey
    3,426
    185
    Mad Mark is offline
    Re: Brake booster convertion problems
    None!
    Sorry mate, I got a kit form Danchuk for my '55 and it all worked. Have you contacted the Toyota garage for any ideas? I called the rover garage when I had a 3.5 in my Granada for help. They were very professional. Try them!
    Hornchurch, Essex
    2,515
    9
    30psi is offline
    Is the piston fully returning inside the master cylinder?
    23,476
    First thing is the bore of theToyota m/c anywhere near the right size for your set up ? I woudl have thought you'd end up with a long pedal and that may be the reason for the stickig as it's operating outside its design .
    What bore are you calipers / slaev cylinders and the Toyota m/c?
    1. Daily problems again!!!!!
      Last Post: 13-05-2010, 20:14
    2. Brake booster and mastercylinder
      By MOPARCRAIG in forum Stuff - FOR SALE
      Last Post: 12-05-2010, 18:41
    3. Master Brake and Booster needs room
      By ProMetalShop in forum Tech Features
      Last Post: 22-04-2010, 23:42
    4. Imagecave problems???
      By bigyellataxi in forum Chat
      Last Post: 17-10-2009, 19:51
    5. BBC running problems
      Last Post: 18-06-2009, 08:35
