Which brake master cylinder?
Results 1 to 4 of 4
    Jul 2009
    Yeovil, Somerset
    1,769
    822
    Stroprock is offline
    I am now thinking about what i should do with brakes on the Austin. I have Triumph Spitfire front brakes and Reliant Kitten rear brakes, so that means front calipers and rear drums. Because of this, does that mean I can't use the master cylinder from the Kitten, and I must look elsewere for a suitable cylinder?
    23,984
    If you haven't messed with the pedal ratio a 3/4" bore ( aboiut 19mm) should do that OK . Would be better feeling with a servo as well though but would stop on a 3/4 alone.
    Jul 2009
    Yeovil, Somerset
    1,769
    822
    Thanks. Surely different 3/4" cylinders have different strokes?
    23,984
    Stroke is controlled by pedal ratio which gives the feel. The amount of fluid moved by the m/c vs the amount of fluid requirement of your wheels cylinders/ discs = amount pedal moves.
    Fluid is displaced equally ( Pascals Law) .
    Pressure produced at pedal (pi x r2 x h x pedal input ( generally accepted as max of 100lbs) x pedal ratio) is spread evenly throughout the system and applied to surface area of 'receiving cylinders . From there it gets far more complicated with available brake material area vs coefficient of friction of material.
    Couple of basic articles belowI wrote ages ago to give a bit of insight.
    UK Hot Rods: News, tech, chat, email group for hot rods, street rods and kustoms
  1. Wanted - MGB single line brake master cylinder
    By klassicdave in forum Stuff - WANTED
    Last Post: 27-08-2010, 11:45
  2. clutch/brake master cylinder
    By hotrodguy in forum Stuff - WANTED
    Last Post: 04-07-2010, 10:55
  3. Lockheed brake master cylinder
    By gez toxi-coco in forum Tech Discussion
    Last Post: 07-04-2010, 17:48
  4. Tri-five brake master cylinder
    By 56chevynut in forum Tech Discussion
    Last Post: 28-02-2010, 18:43
  5. duel brake master cylinder with servo for tri 5
    By punk in forum Stuff - WANTED
    Last Post: 26-12-2009, 17:39
