Brake master push rod
Results 1 to 4 of 4
    Nov 2011
    suffolk
    5,974
    1410
    russ6120 is offline
    Should the rod insert be flush? I had to machine one I had to fit but not sure on the length
    22,831
    When built up there should be 1mm of free play ie enough to easily rotate the push rod between your fingers . Thta's from a servo unit though isn't it so how are you going to keep it in there ?
    Nov 2011
    suffolk
    5,974
    1410
    russ6120 is offline
    It does go onto a servo. I thought it might be sticking out an it far as the cylinder didn't sit flush with the servo unless I tightened it up. I'll lathe a bit off
    Nov 2011
    suffolk
    5,974
    1410
    russ6120 is offline
    There is also an o ring holding it in nice n snug
    1. So Cal Brake pedal push rod
      By Hemi Bucket in forum Stuff - FOR SALE
      Last Post: 22-02-2016, 21:08
    2. Tri-five brake master cylinder
      By 56chevynut in forum Tech Discussion
      Last Post: 28-02-2010, 17:43
    3. Another Tri-five brake master question
      By Neil G in forum Tech Discussion
      Last Post: 27-02-2010, 21:52
    4. brake master clyinder size ?
      Last Post: 23-01-2010, 20:20
    5. duel brake master cylinder with servo for tri 5
      By punk in forum Stuff - WANTED
      Last Post: 26-12-2009, 16:39
