Brake problem Consul 375
Results 1 to 5 of 5
    I'm a newbie !
    Aug 2014
    Essex UK
    9
    jcundall is offline
    I've bled the brakes 2/3 times and can't get a decent solid brake, the shoes are adjusted correctly. Any tips please!?
    Oct 2009
    grays essex
    376
    16
    sebspeed is offline
    clamp all the brake hoses off, and if the pedal is still soft you know its a dodgy master.but if the pedal is still hard, then remove one clamp at a time to determine what brake is giving you a problem.
    I'm a newbie !
    Aug 2014
    Essex UK
    9
    jcundall is offline
    Just noticed when pumping brake pedal there are air bubbles in the brake cylinder. Does this mean it needs replacing, thanks
    Nov 2011
    suffolk
    6,069
    1426
    russ6120 is offline
    It is possible that the master cylinder is dragging air in. Are there any signs of leaks? You'll have to look under the dash to see where the brake pedal goes to the master cylinder if I remember correctly. I don't know what you've done to your brakes but it might be worth changing all the flexi hoses while you're at it. Better safe than sorry and all that stuff
    Apr 2010
    telford, shropshire
    389
    john w is offline
    A tip worth trying is one I had years ago on a Wolseley 16/60 auto I had. Pump the brake pedal untill the pedal is hard then wedge a piece of wood between the pedal and a piece of wood wedged against the front of the drivers seat and leave it like that overnight. Any bubbles of air will probably find their way up through the master cylinder. This has worked a few times for me, might not always work but worth a try.
    1. consul 375
      By modxl in forum Tech Discussion
      Last Post: 08-09-2010, 21:06
    2. Brake Servo Unit - 1961 Ford Consul 375 Lowline
      By THE POP SHOP in forum Stuff - WANTED
      Last Post: 13-08-2010, 20:21
    3. consul 375
      By modxl in forum On Topic
      Last Post: 20-07-2010, 19:16
    4. my 1965 2000 p6 v8 an consul 375
      By symes in forum The Showroom
      Last Post: 29-06-2010, 15:57
    5. strange brake problem
      By renegade53 in forum Tech Discussion
      Last Post: 17-04-2010, 22:18
