Brake servo or not....
Results 1 to 10 of 14
    General tool abuser 2doorConsul's Avatar
    Nov 2009
    Ireland
    64
    2doorConsul is offline
    Put a Tina mk3 clip on the front of the mk2 Consul,..Fitted 300mm discs and granny mk2 calipers, 2.9 v6 efi granny ,auto box.....As its an auto i dont need the clutch..if i make the pedal box to operate the two m/cylinders do i need a servo fitted..the rears are drums.....i have a servo lyin around if needed...
    Rods 'n' Sods Junkie tony lewis's Avatar
    conwy
    390
    117
    tony lewis is offline
    i would fit a servo if i were you i run front discs and drums on rear with no servo and its ok not brilliant and as iv got bugger all power in mine compared to yours (1400 moggy)you may find you need to stop in a hurry one day and be very thankful for the servo iknow its extra work expense etc but im sure it'll be worth it in the long run
    Nov 2009
    Ireland
    64
    Tanx mate, so you dont think the double m/c will suffice then..?
    23,747
    A double m/c generates far more braking power than a single doing the same . However this is only true if you use an adjustable bias bar, if both are pushed equally ther is no more power than a single set up.
    Personally I'd use a servo wherever possible as while dual m/cs work they take some getting used to.
    Nov 2009
    Ireland
    64
    One of the m/c shafts is adjustable, so i'm guessin it would take a bit of fettling to get everything right...With the brakes i have i was going to use a m/c for each i.e front and back..is this the way to do it or will i just go with the servo...
    23,747
    It's not just the rod length that has to be adjuatsble it has to have a method of swivelling in the middle of the 2 m/cs . This give details of the general set up .
    http://www.wilwood.com/TechPedalTip.aspx
    Nov 2009
    stourport
    5,531
    7
    beach57 is offline
    Best opption is to use the brake master and servo that came with the cortina clip no guess work then.
    Nov 2009
    stourport
    5,531
    7
    beach57 is offline
    Also pedal leverage recomendation is 7 to 1 servo, 9 to 1 non servo.
    23,747
    ..and most standard cars are 4 to 5:1 range so pedal pick up points would need modifying.
    Official RnS Addict rootesix66's Avatar
    north kent
    1,112
    191
    rootesix66 is offline
    without trying to give any advise lets just weigh up some comparisons......
    1.ford prefect.2.1 pinto.2.8capri discs up front 107e drums rear,servo, soft pedal works fine
    2.ford mustang 1968,all original drums all round,no servo medium pedal works fine
    3 1947 chevy panel van ,drums all round,no servo,medium pedal works fine
    4. humber hawk ,custom 4 pot billet callipers front on295mm
    custom discs,rear ,cosworth discs/caliipers.servo on front,bias valve ,no servo on rear,works great (medium hard pedal)
    so many combinations...so litltle time,money,etc
    crazed country rebel
    1. duel brake master cylinder with servo for tri 5
      By punk in forum Stuff - WANTED
      Last Post: 26-12-2009, 16:39
    2. Servo
      By CRAIG in forum Tech Discussion
      Last Post: 29-11-2009, 16:17
    3. Replies: 3
      Last Post: 16-11-2009, 00:00
    4. Viva brake servo and master cylinder
      By ThomasHarris in forum Stuff - FOR SALE
      Last Post: 06-10-2009, 21:28
    5. Mini heater. Brake servo.
      By Lee in forum Stuff - WANTED
      Last Post: 27-04-2009, 19:04
