BSP or NPT threads?
Results 1 to 5 of 5
    Rods 'n' Sods Junkie petespops's Avatar
    Kent
    479
    19
    petespops is offline
    QuestionBSP or NPT threads?
    I have a SBF alloy inlet manifold and need some unions and blanking plugs.
    Are they BSP or NPT threads?
    Cheers
    nottafukinchancingham
    7,882
    57
    Torment is online now
    probably npt (national pipe taper)...or something..
    bsp is british standard pipe...hope this helps...
    (unzips anorak,returns it to the cupboard.)
    57 chevy wagon.
    540cui altered.
    Cheltenham
    4,076
    601
    fozwanger is offline
    In a nut shell, they are almost the same. A BSP will screw into an NPT hole and an NPT will screw into a BSP thred although there will only be a couple of threads with full engagement in both instances (i.e thread will not be of full strength).
    The only difference is the flank angle on the thread form. If my memory serves me correctly (poof, blow away cobwebs from my hydraulic days) the flank angle on a BSP is 60 deg and NPT is 55 deg.
    If it's yank then it'll be NPT although BSP fittings are easier to obtain over here. Good hydraulics shop will have both.
    Are the fittings under pressure (I mean anything above about 100 psi?) as gas is far more searching than a fluid so will need a getter fit.
    Hope this helps, sorry to waffle. If you want me to check flank angles for you let me know and I'll dig out mt thread charts.
    Jeff
    489
    langy is offline
    They are definitly NPT, I keep them in stock if you need. Some are 1/2" or 3/8"
    Cheltenham
    4,076
    601
    There you go :-)
    1. old threads
      By Evil McNasty in forum Chat
      Last Post: 13-03-2010, 18:57
    2. Deleting threads?
      By Lee in forum Chat
      Last Post: 12-05-2009, 12:41
    3. Only 4 more threads ...
      By Roadrunna in forum Chat
      Last Post: 07-05-2009, 21:06
    4. BUILDUP THREADS, where ???
      By langy in forum On Topic
      Last Post: 29-04-2009, 01:14
