c4 gear box problem
Results 1 to 10 of 19
    Official RnS Addict old pizz yella's Avatar
    Aug 2009
    Hyde Cheshire
    1,122
    68
    old pizz yella is offline
    c4 gear box problem
    well my little coupe is naffing about agian
    the gear box is a c4 with a b+m shift improver kit in the valve body (fitted by me that could have been a mistake lol)followed the instructions to the letter and ajusted the bands as it says in my chiltons book ,it now has a new modulator with new lines and the fluide level indicates its full ,
    it also has an alloy tube +finned coolers with 1/4 hoses (i am going up these to 3/8ths hoses very soon )
    so the problem is the shift from 2nd to 3rd the revs flare up by about 500 revs while just blobbing about and about 1000 rpm when you give the loud peddle ,ive redone the intermediate band adjustment still doing the same thing the servos are the originals i did take them appart to clean them whe the box was out last i would really like to fix this with out taking the box out as its a bit of a pain to get out lol
    cheers gents
    Leicester
    5,696
    594
    bigyellataxi is offline
    Dunno, I am sure Mr Frost will be along soon though...
    Fueled by Jim and Luckies.
    Aug 2009
    Hyde Cheshire
    1,122
    68
    hows it going guy you and your good lady ok mate not seen you for some time hows the zeph
    wolverhampton
    1,392
    redvictor is offline
    Quote Originally Posted by old pizz yella View Post
    cheers gents
    what did you adjust the front band to? How many turns? is it a fine thread or coarse thread on the band adjuster? Fine thread requires 3 turns but you can go as low as 2.5 turns.Coarse is 1.5 turns.
    If adjsutment doesn't cure it do you know that the direct clutch is ok? Intermediate servo seals? direct clutch sealing rings? intermediate band?
    Aug 2009
    Hyde Cheshire
    1,122
    68
    hi Andy ,Cheers for the reply .the band that ive done is the one in the photo with the kick down on it
    the one at the rear next to the mod is the low band according to my book
    i have noticed that this servo seams to be seeping fluid could this be faulty and can they be repaced?
    could i be adjusting the wrong band?its the one my chiltons book said to do for this fault (tighten to 10ft/lbs then turn back out 1 3/4turns )
    once its in gear theres no probs its just engaging 3rd when it flares
    your help is much appreciated
    Leicester
    5,696
    594
    Fine ta dude, hopefully see ya at the HRD's...
    Zodi is fine, it will be just looking pretty though at Shakey, no point in racing, it ain't got any quicker...
    Aug 2009
    Hyde Cheshire
    1,122
    68
    groovey
    it dont matter if it aint quicker its a laugh
    wolverhampton
    1,392
    Yes you are correct. Front adjuster is intermediate and rear is low/rev band.
    The servo has a gasket under the cover that can be changed.(did you replace it or even leave it off?
    If it didn't flair before either the shift kit is installed wrong,or the feed holes are different in the plate that has uncovered an underlying fault that was there before...
    You'll need to check it all over to find out what the problem is..let me know how you get on..
    Aug 2009
    Hyde Cheshire
    1,122
    68
    cheers mate
    carnt remember about the gasket,i`ll have a look tomorrow and have a look if the valve body is all in correctly ,do you have c4 valve bodys just incase lol?
    cheers keith
    ive had a read up about the servo and there are a few different ones (letters )do theses make any difference ?
    Leicester
    5,696
    594
    groovey
    It could also be expensive, and I have to drive it to work on the Monday...
    1. Charging problem
      Last Post: 14-05-2010, 16:10
    2. 85 z28 fuel problem
      By tuckers in forum Tech Discussion
      Last Post: 03-05-2010, 12:07
    3. V6 oil pressure problem
      By Tiddytime in forum Tech Discussion
      Last Post: 22-11-2009, 20:33
    4. Browser problem
      By kapri in forum Chat
      Last Post: 21-10-2009, 23:22
    5. Chevy gear box problem
      By DeuceTudor in forum Tech Discussion
      Last Post: 08-08-2009, 22:46
