cam /distribitor problems
Results 1 to 10 of 10
    Official RnS Addict keith ardley's Avatar
    MEPAL Nr Ely cambridgeshire
    659
    410
    keith ardley is offline
    Questioncam /distribitor problems
    Hi I hope there's someone that can help sort out my v8 60 have fitted a fast road cam along with a Malory electronic distribitor will start up on the button and if need be tick over all day but try to drive it and it just bogs down tickle the throttle and then its possible to get it to go but the same thing happens at the gear changes (by the way it has a c4 auto box )
    had the carbs rebuilt,(twin strombergs no 81 ) been in to two well known hot rod shops with out any results just a big dent in my pocket sourly someone knows these engines after all thay were raced a lot in midgets
    23,342
    How are the plugs looking rich /weak as the sympthoms could be down to either condition.
    How are the twin carbs fitted up 2 on a common plenum or 2 feeding 4 cylinders?
    659
    410
    how are the plugs looking rich /weak as the sympthoms could be down to either condition.
    new set of plugs black as soot have the smallest jets and pump settings rebuilt by stromberg (clive prew ) made a smashing job of them on a hollywood manifold not certain what is ment by plenum ?
    But it seems as though 1 carb feeds each set of 4 pots i think ! As it wont run on the one tried that i wondered if its any thing to do with the auto box taking the vacuum from the manifold
    23,342
    The vacuum shouldn't as it's 'closed' circuit unlike a brake servo which loses the vacuum when operated .
    Your answer re the carbs looks like it isn't over carbed. Do these carbs use power valves operated by engine vacuum ? It's possible that the wilder cam is losing engine vacuum and allowing the power valves too cut in too soon ( if they are fitted ?) .Has anyone done a vacuum check on the engine and compared it with the power valve ratings?
    659
    410
    FONT="Comic Sans MS"] NOW YOU HAVE LOST ME !! TEL YOU THE TRUTH THAT'S WY I SENT IT TO A FLAT HEAD HOT ROD SHOP TO GET IT FIXED BUT ALAS STILL NO BETTER AND A BIG HOLE IN MY POCKET [/FONT]
    23,342
    Keith, I'm no expert ( or even novice) on flatheads or Strombergs ,just applying basic knowledge to your problem. I'm surprised that 2 rodshops, presumably specialising in flatheads, couldn't sort it ? But if they do have power valves there are simple ways of immobilising them to rule them out of the equation.
    Did you get any feedback as to possible causes from the shops involved ?
    Nr. Dartford, Kent
    2,725
    244
    stueeee is offline
    Quote Originally Posted by keith ardley View Post
    Have you (or any of the rod shops) checked that you're getting advance from the distributor when you rev the motor? A non operative centrifugal advance can give the symptoms you describe even though it appears to be a carb problem.
    Stuart.
    My Intro
    North Yorkshire
    355
    25
    FlatheadFordV8 is offline
    Does it rev up OK in neutral, i.e. just blipping the throttle?
    Does it go better or worse with the choke set slightly?
    What is the stall speed on the converter?
    Do you know what the advance curve is in the distributor?
    The power valves are mechanical on Strombergs, operated by the accelerator pump rod at wide open throttle, or there abouts.
    Bridgwater
    727
    37
    scooder is offline
    Have you got a stock dizzy and inlet manifold to swap on? Best to try one thing at a time so you can single out the problem.
    My normal firs port of call is that red caped git on the front (dizzy) as so many of the ones suplied for Flatheads have completly rong advance curves in them from the factory, but it is sortable.
    But I cant help but think that 2 81's on a 60 with a bit of cam and an auto box is asking a tad to much. Those little 60's are very touchy on air flow ( you only port a full house 60 in a very light car as the ports are a tad to big to start off with) Too much air and they fall flat on there arse. That auto saps power also ad when you start niking power from an engine that was rated at 60hp on one of old Henry's very happy dino's you aint got much left to scoot down the road with and bugger all torque.
    So my first try would be single 81 on a stock intake, If this improves the car you got it sussed. You realy should check out the advanse curve as well because of what I said earlyer.
    Good luck let us know how it goes.
    Martin.
    659
    410
    Thumbs up
    Quote Originally Posted by scooder View Post
    Martin.
    Thanks Martin Think you are right I have dun so much to it but in no order so as you sagest put it all back to standard and go from there something to do over Christmas pity i got rid of the distribitor but i kno a man that has one i can borrower keep you informd thanks
    1. Daily problems again!!!!!
      Last Post: 13-05-2010, 20:14
    2. Cooling problems
      Last Post: 22-04-2010, 09:56
    3. Imagecave problems???
      By bigyellataxi in forum Chat
      Last Post: 17-10-2009, 19:51
    4. BBC running problems
      Last Post: 18-06-2009, 08:35
    5. 350 Chevy TBI problems
      By Paul G in forum Tech Discussion
      Last Post: 28-05-2009, 12:27
