Cam upgrade kits with springs etc
Results 1 to 10 of 12
    Stroker Kustom Jim's Avatar
    Bath
    5,186
    2753
    Kustom Jim is offline
    LightbulbCam upgrade kits with springs etc
    Looking at some sbc retro roller cam upgrades and you can get a kit and caboodle and not just the cam.
    Which I understand is handy it if it's all from the same company.
    COMP Cams K12-432-8: Comp Cams 'Xtreme Energy' Hydraulic Roller Camshafts | JEGS
    Purely out of technical interest when they say stock springs no good etc that throws up a few questions...
    (bearing in mind heads are mild Edelbrocks to start with - and I wouldn't ignore recommendations)
    1, does it mean that generally the stock springs will be too weak and valves may float ?
    2, stock springs may crush with the extra lift - stock head says max lift .490 and new cam claims .520
    C, does that not make the actual valves/stems too short or summat ? unlikely I imagine, what's 30 thou between friends - no kits state new valves required, just wondering.
    4, also states heads need machining! what for ?
    many thanks in advance
    Jimbob
    13,149
    in order 1- yes
    2- they may get coil bound
    3/4- valves ok but as the lift is more than the max' of the head the guides where the seal sits will need machining down so the keeper/retainer doesn't hit it
    Bath
    5,186
    2753
    Brilliant reply.
    Give that man a ceegar
    Jun 2016
    Roswell, New Mexico
    843
    NMNeil is offline
    Stronger valve springs are only needed if you are going to rev the motor above 6000 rpm
    23,476
    in order 1- yes
    Hornchurch, Essex
    2,515
    9
    30psi is offline
    I wouldn't guarantee that. I've seen stock springs on a big block Ford that were very weak. I could open the valves with the base of my palm easily.
    For the sake of the extra cost, it's best to spend the extra money on new springs. You never want a valve being a bit indecisive about returning to its seat whilst its got a piston coming up close to its face.
    '62 Ford Thunderbird
    '81 Datsun Bluebird SSS Turbo
    13,149
    Quote Originally Posted by 30psi View Post
    Jun 2016
    Roswell, New Mexico
    843
    NMNeil is offline
    True, but I only meant stock springs in good condition.
    The only reason for using stronger springs in a engine is to overcome the valves inertia at higher than factory rpm's.
    Putting stronger springs in a stock engine simply increases stress and wear on the valvetrain.
    13,149
    not just higher rpm, some cams have much steeper ramps on the lobes that require more valve control.
    Herts
    4,616
    224
    WB54 is offline
    Head may need skimming to achieve correct compression ratio
    1. '47 to '53 Chevy truck springs, etc
      By v8.jimmy in forum Stuff - WANTED
      Last Post: 06-02-2014, 22:53
    2. Ford axle, springs etc.
      By Broken Arrow in forum Stuff - FOR SALE
      Last Post: 24-11-2012, 10:53
    3. Replies: 5
      Last Post: 10-05-2012, 10:26
    4. Replies: 1
      Last Post: 26-09-2010, 20:18
    5. More old kits Beetle Camper etc
      By Stitch in forum Stuff - FOR SALE
      Last Post: 06-01-2010, 13:44
