camaro master cylinder info
Results 1 to 3 of 3
    Rods 'n' Sods Junkie dez58pop's Avatar
    Jul 2011
    sheffield
    342
    91
    dez58pop is offline
    i have fitted all the running gear from a 3rd generation iroc camaro into my 56 chevy truck.the problem now is there is 3 outputs on the block out of the master cylinder.there is 2 /normal 3sixteenth out and one quater inch.so which goes to the front and rear.by the way i have now made the quater inch out take standard pipe as i have a jag front clip on.cheers
    23,272
    yanks cylinders don't follow European convention. Simplest way or them is biggest reservoir is for the front brakes, usually the 1/4 is a rear line.
    Apr 2012
    Thirsk, North Yorkshire
    70
    5
    wanderingkurt is offline
    the two 3/16 are front left and right. the 1/4 is the rear which you run up to the rear axle and split with a "T" fitting.
    1. Clutch Master cylinder identification!
      By heathy12 in forum Tech Discussion
      Last Post: 29-12-2009, 16:39
    2. Master cylinder + Rad For Sale
      By bigyellataxi in forum Stuff - FOR SALE
      Last Post: 17-10-2009, 19:57
    3. Viva brake servo and master cylinder
      By ThomasHarris in forum Stuff - FOR SALE
      Last Post: 06-10-2009, 22:28
    4. 39-46 Ford Master Cylinder
      By RustyA in forum Stuff - WANTED
      Last Post: 21-07-2009, 10:04
    5. What clutch master cylinder?
      By Mudgie in forum Tech Discussion
      Last Post: 25-05-2009, 20:32
