Camaro tpi diagnostics
Results 1 to 10 of 17
    I'm a grown up member now ! Tri5's Avatar
    Jun 2010
    Gosport Hampshire
    87
    9
    Tri5 is offline
    Does anyone know anyone in the Southampton/ Portsmouth area that has the ability to diagnose a TPI issue on an 86 Camaro 305 engine that will not start when up to temperature please?
    23,198
    Can't think of anyone locally that's likely to have the correct equipment .
    The only change you've made to the wiring is petrol pump straight off ignition and rest of loom and parts location per standard?
    Is it just when you turn it off Alan or does it misfire or any other symptoms before it won't start ? How long does it have to run before it won't start again? Will it stop and start OK UNTIL it gets warm? and( almost) lastly did you get to check the injection noids both when starting from cold and when it won't start ?
    Sparks at plugs when it won't start ,just to point if more likely to be fuel than electrics switching ? If sparks there have you tried squirting fuel down the air filter ?
    23,198
    Feb 2010
    Selby north yorks
    1,939
    129
    rodster is offline
    Rods 'n' Sods Junkie nelly's Avatar
    Jul 2011
    Gloucester
    209
    15
    nelly is offline
    I would also suggest a reader to diagnose it yourself. Are you a member of Thirdgen.org, huge 82-92 Camaro/Firebird forum
    Procharged 406ci 92 Camaro
    Jun 2010
    Gosport Hampshire
    87
    9
    Tri5 is offline
    Thanks everyone. It runs and starts fine until I turn it off with the key. When I try to restart it just won't fire unless I give it a squirt into the plenum and then she'll fire a few times and start.
    Plugs have good spark hot and cold and injectors have constant 15 ohm both hot and cold, but no light when cranking.
    The cold start injector has 3 ohm constant.
    Dizzy if cos I have replaced everything inside and to be sure even swapped distributors with my 89 corvette engine and still has the same problem.
    Good fuel pressure throughout 42psi.
    Just no injector pulse when cranking.
    ECU?
    Jun 2010
    Gosport Hampshire
    87
    9
    Tri5 is offline
    Yes Nelly,
    Really good forum and I have also used Chevy Thunder in the past.. Some great info there too.
    Jun 2010
    Gosport Hampshire
    87
    9
    Tri5 is offline
    Jun 2010
    Gosport Hampshire
    87
    9
    Tri5 is offline
    I'll check tomorrow to see if the diagnostic connection is there.. Thanks.
    Nov 2009
    stourport
    5,529
    7
    beach57 is offline
    Does it start if cold ,ie start run for about a min from cold then stop then start does it then run .Also what is oil pressure when hot.
    1. Replies: 14
      Last Post: 06-04-2014, 00:21
    2. TPI & third gen Camaro parts for sale
      By Octane-Rat in forum Stuff - FOR SALE
      Last Post: 12-05-2012, 19:45
    3. wanted tpi fuel pump in tank corvette/camaro
      By Crookes37ford in forum Stuff - WANTED
      Last Post: 04-07-2011, 20:58
    4. 1st gen Camaro tacho question
      By evilzee28 in forum Tech Discussion
      Last Post: 10-05-2009, 20:26
    5. Replies: 12
      Last Post: 07-05-2009, 16:18
