Charging problem
Results 1 to 10 of 12
    Official RnS Addict yorkster's Avatar
    Jul 2009
    leicestershire
    572
    42
    yorkster is offline
    Charging problem
    Right then i've had a multitester on my battery whith the engine running and its not showing a charge,its a single wire alternator with a smaller wire coming out of it that i assume should go to a warning light,i havent connected this and after stripping the alternator off im now thinking that if i piggy backed the small wire to the B+ on alternator maybe it would exite it to charge..am i wrong or should i take it in to be checked out?
    cheers
    Nov 2009
    stourport
    5,531
    7
    beach57 is offline
    Re: Charging problem
    Poss a bad earth engine to chassis chissis to battery
    Jan 2010
    kilmarnock
    250
    93fxdl is offline
    i am the type who knows naff all about electrics (if you cant fix it with a hammer i am stuffed) but have read on other forums that some alternators need the warning light to operate, something about power to energise the alternator to get it working
    hopefully someone will be along who can help but if not try wireing up the warning light but whether it goes to pos or neg i havent a clue
    ttfn glenn
    Rest in Peace
    Earl Shilton
    4,385
    1117
    SG57 is offline
    The warning lamp wire comes from the ignition switch and is pos, it goes to one side of the warning lamp and the other side (of the lamp) goes to the small terminal on the Alternator and hey presto!
    Rog.
    If some's good, more's better and too much is just enough
    Nr. Dartford, Kent
    2,725
    244
    stueeee is offline
    What model of alternator? If it is a true 1 wire alternator it would only have the battery connection.
    Earlier Lucas have battery and field -the field needs to go to positive from your ignition switch via a warning lamp if you want one. If it's a field connection don't connect it to a permanent live or you'll find your motor keeps running when you turn off the ignition due to a condition called field circuit backfeed.
    Yank or Jap alternators usually have different wiring again.
    Stuart.
    Stuart.
    My Intro
    Jul 2009
    leicestershire
    572
    42
    yorkster is offline
    thanks for the replies.its a bosch unit off an alfa romeo,im thinking that i may have to pull a sickky from work to go and try it.
    Jul 2009
    leicestershire
    572
    42
    yorkster is offline
    ok i've got it working after flashing the charge light wire to live so then i connected it to the live after the ignition switch and like stu said the engine wont turn off unless i disconnect the wire,i cant just flash the wire every time i want to use it so how else can i wire it??
    cheers
    Kent
    424
    8
    Morecubes is offline
    You need to connect that "charge light wire" to one side of a bulb (ign warning light) - the other side of which is connected to an ignition fed live - once started one positive cancels out the other - the light goes out & hey-presto the alternator charges !
    Jul 2009
    leicestershire
    572
    42
    yorkster is offline
    Quote Originally Posted by Morecubes View Post
    excellent thanks.
    Kent
    424
    8
    Let us know how you get on ?
  1. 85 z28 fuel problem
    By tuckers in forum Tech Discussion
    Last Post: 03-05-2010, 13:07
  2. Alternator charging "issues"
    Last Post: 20-04-2010, 16:45
  3. Browser problem
    By kapri in forum Chat
    Last Post: 22-10-2009, 00:22
  4. c4 gear box problem
    By old pizz yella in forum Tech Discussion
    Last Post: 16-08-2009, 16:57
  5. Braking problem
    Last Post: 18-07-2009, 22:34
