Chevy truck column change linkage
Results 1 to 4 of 4
    22,885
    I'm re-assembling my mates '53 truck and although I'm putting it back as taken apart it doesn't look right to me . The shifter rod furthest from the driver is on an angle is assembled as it came apart .ie there is a plain shank that goes through a rubber push which then takes a washer and split pin.
    Both of these point down the shaft towards the steering box. To make them go in straight the bottom one wants taking off and reversing so the pin points upwards ?
    Coudl someone take a look at their linkage and tell me which way is correct please ?
    cheers
    Kev
    _______
    Official RnS Addict ironman56's Avatar
    Jul 2010
    bomber county lincs
    977
    118
    ironman56 is offline
    Hi, would this be the same as on a column change tri chevy car?, if so, had the same problem, as the bloke i bought the car from had the "arms round the wrong way..
    Try it with the pins facing outwards, with the split pins on the outside of each arm,rods on the inside of each.
    should give you the clearance to change gear, and not fowl anything..
    Hope this comes across ok..will try find a few pictures to help.
    Only other thing to do, is see if a panel van/truck owner has a build sheet...
    22,885
    Wow, you dragged up an old one here Motor got sorted but buggered if I can remember what we did without looking at it again
    Jul 2010
    bomber county lincs
    977
    118
    lol...i have just seen the date stamp on that...thought you might have it sorted by now..even by my standards it was a while ago..just thought i would stick a reply up...you never know
    I still have a 66' pontiac in bare metal after 4 years..lol..(still as good as the day it was stripped;-)
    1. c4 auto linkage for column shift.
      By Micks47 in forum Tech Features
      Last Post: 10-05-2012, 20:48
    2. mk3 column change 4 speed box
      By hepcat in forum Stuff - WANTED
      Last Post: 20-08-2010, 12:12
    3. WANTED: Steering column to dash bracket 55 Chevy truck
      By Motorama in forum Stuff - WANTED
      Last Post: 27-02-2010, 18:25
    4. Manual shift Linkage for Tri Chevy
      By Tark in forum Stuff - WANTED
      Last Post: 06-07-2009, 20:07
    5. Replies: 2
      Last Post: 07-05-2009, 19:22
