Cleaning rover v8 injectors
Results 1 to 5 of 5
    Banned
    Jun 2010
    wirral
    1,278
    386
    2
    Willys V8 is offline
    Four of my rover v8 fuel injectors need cleaning, my local injector place has closed down and I,m going to have a go myself. I have a small sonic bath and am going to use panel wipe in it? I read on web that this is the stuff to use? Your thoughts folks? Cheers.
    Feb 2017
    Cramlington, Northumberland
    39
    ford34/2 is offline
    All 8 of ours were stuck closed. When the 3 volts was applied you could hear them click, however the plungers were stuck. So rigged up 3 volt supply to the conections,slipped a socket or a pipe over them, and clonked them quite hard on a lump of wood to shock the plunger into releasing. Then I also connected a pressurised petrol supply with an air line pumping it through, set the air line at about 35PSI you should eventually get a nice even mist, let loads and loads squirt through. It will clean out any gunge, If the engine has stood for any length of time its a common problem. But after running every diagnostic check, voltage to injector etc,etc , after weeks of frustrating failures. the problem was indeed stuck plungers in the injectors-- not letting fuel through.
    So in a nutshell you need a container to pressue up to 35PSI and this needs an outlet for the pressurised petrol and it needs to be connected to the injector, you need a couple of 1.5V batteries connected to make 3 volts and they need to be connected to the injector electric connector, and a sleeve to slip on the injector - mission to free the plunger and allow a mist of petrol through. There are injector cleaners, possibly squirted in the injector and left to soak, and then 3 volts and 35 PSI, see if it squirts through.
    Stan
    Feb 2017
    39
    ford34/2 is offline
    I understand The Engine is now running, Possibly the above worked?
    Nice one.
    Stan
    Banned
    Jun 2010
    wirral
    1,278
    386
    2
    Yes, as I said in my pm, spot on. Cheers bud.
    Feb 2017
    39
    ford34/2 is offline
    1. Rover V8 Engine block cleaning
      By 302zeph in forum Tech Discussion
      Last Post: 08-02-2015, 20:10
    2. Cleaning a supercharged rover v8
      By Scott in forum On Topic
      Last Post: 07-02-2011, 19:59
    3. rover 5sp manual box
      By hotrodguy in forum Stuff - FOR SALE
      Last Post: 15-05-2009, 19:30
    4. rover v8
      By pompeypaul in forum Tech Discussion
      Last Post: 04-05-2009, 17:37
    5. Rover V8 - Offers, Surrey
      By Smithy in forum Stuff - FOR SALE
      Last Post: 24-04-2009, 20:35
