clutch drag
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 27
Thread: clutch drag
    Official RnS Addict yorkster's Avatar
    Jul 2009
    leicestershire
    572
    42
    yorkster is offline
    clutch drag
    took the truck for its mot today(it passed)and on the way back i had difficulty in selecting gears,its got a new clutch fitted and its hydraulic so i've got no adjustment,im certain i bled it through ok and it was fine on the way there(25 miles) its definatley dragging and gets marginally better if i pump it,can you shim the clutch arm out or is this a bad idea?
    cheers yorkie
    Official RnS Addict Zody's Avatar
    Sussex
    1,772
    Zody is offline
    Re: clutch drag
    Quote Originally Posted by yorkster View Post
    cheers yorkie
    Blimey that takes me back to the old Mk1 cortina days, when fitting a new clutch kit, It's was the norm to put a dust cap over the end of the clutch rod, at least 100 mile, and then remove it, the aftermarket clutch kits had a thick centre plate pad, (compered to the factory ford units) which used to cause the drag, until worn abit.....
    Worked wonders
    The car is open, the keys are under the dog !
    23,556
    Re: clutch drag
    Is it the correct clutch pushrod ? Do you get full slave travel ie to the inner circlip. I've had it before that the pushrod ( non adjustable) was too short. Neded lengthening ( as Zody says to get full travel)
    Jul 2009
    leicestershire
    572
    42
    yorkster is offline
    Re: clutch drag
    right then when i said new clutch i only fitted the friction plate so i think i've f**ked up,i've got full travel on the clutch arm and as soon as you touch the lever it moves the arm so i think its a new pressure plate!! yeah i know i should have swapped it when i done the friction plate..what a dickhead!!
    well you live and learn
    Herts
    4,617
    224
    WB54 is offline
    Re: clutch drag
    might not be, could be a warped flywheel surface or the seals in your slave cylinder are shot. Fit the new pressure plate but if it only gets better after pumping the pedal, rebuild the slave.
    Jul 2009
    leicestershire
    572
    42
    yorkster is offline
    Re: clutch drag
    its a brand new slave cylinder so i should be ok,it was fine going over it was on the way back it started playing up.
    Oct 2009
    East Sussex
    83
    ironheadpaul is offline
    Re: clutch drag
    Presume master cylinder is not leaking or creeping back - not too much clearance (free play) between pedal pushrod and master cylinder piston
    Jul 2009
    leicestershire
    572
    42
    yorkster is offline
    Re: clutch drag
    i've been out and shoved a large washer inbetween the pushrod and arm to hopefully get it over to my unit,there was a bit of a gap between the two so dunno if its supposed to be like that,if its ok on the drive over maybe itts the pushrod??
    Nr. Dartford, Kent
    2,725
    244
    stueeee is offline
    Re: clutch drag
    its a brand new slave cylinder so i should be ok.
    Might be worth checking that your new slave cylinder hasn't got a larger bore than the old slave cylinder. The larger bore would reduce the clutch arm travel Vs. pedal travel.
    Stuart.
    My Intro
    23,556
    Re: clutch drag
    Giev me an age/model for the engine and I can check if there are different slaves for it.
    1. SBC Clutch Kit and Headers
      By Paul Y in forum Stuff - FOR SALE
      Last Post: 06-04-2010, 23:14
    2. New Chevy 11" Clutch kit
      By Dragsterbus in forum Stuff - FOR SALE
      Last Post: 31-03-2010, 22:29
    3. clutch return spring
      By jack earls in forum Stuff - WANTED
      Last Post: 21-03-2010, 10:21
    4. clutch parts
      By MarkV8 in forum Stuff - FOR SALE
      Last Post: 20-11-2009, 18:38
    5. Clutch help needed
      By sidspop in forum Tech Discussion
      Last Post: 14-10-2009, 17:01
