Clutch master cylinder
Results 1 to 10 of 10
    Burn out champ 2010 Dusty's Avatar
    Northants
    1,691
    223
    Dusty is offline
    I have had no end of trouble with the clutch in my Austin.
    I shall be buying a new master cylinder tomorrow and re-plumbing the whole system.
    If I replace the 0.625" bore cylinder with a 0.750" one will the clutch feel noticeably heavier?
    It didn't feel particularly heavy when it was working and I'm hoping that moving more fluid may improve it.
    At the moment the master and slave are a matched new pair, designed for the Essex V6 and overdrive gearbox that they are attached to.
    Sep 2011
    Kings Lynn
    3,330
    459
    brading is offline
    Might pay to read what Kapri says in this thread
    https://www.rodsnsods.co.uk/forum/tec...over-v8-327498
    Herts. and ahead of Larry :)
    2,640
    34
    chevy2 is offline
    If its a girling type like whats fitted to mk2 cortinas etc theres one size in between at 0.700".
    23,985
    What was the set up from as I can check in my books as to OEM fitment. What problem do you have , clipping gears by any chance ie doesn't quite clear when trying to engage ?
    Northants
    1,691
    223
    Dusty is offline
    Reliant Scimitar. New cylinders from a specialist which worked for a while but yes, those symptoms Kev although reverse is most troublesome.
    Struggling and failing to bleed the system this time.
    I pressure bled the system by putting the Gunson spare wheel device on the master and a vacuum sucker on the slave. Pressure at the pedal for one push and then gone again.
    The red translucent pipe doesn't show signs of leakage so I'm pretty much stumped.
    The m/c and pipe are very similar to the Marina
    Northants
    1,691
    223
    Dusty is offline
    Full story...
    Both cylinders were rusted and seized when I got the car. I bought new ones from a specialist which although not cheap seemed the obvious and quickest solution. The clutch worked okay but didn't really feel right.
    I lost the clutch while driving around and discovered fluid running down the bulkhead. QRG exchanged it with no quibbling and I had a clutch again.
    I moved the car around last week and all seemed fine. A few minutes later I got in the car and found the pedal up under the dash with the pushrod hanging off it. I replaced the circlip with a stronger one and fabricated a pedal stop.
    Since then I have been unable to achieve a working clutch.
    I have noticed that during the bleeding process, pushing the pedal down causes the fluid to rise toward the filler rather than forward. My deduction is that there is a problem with the seals. The pushrod is definitely coming far enough back, my new stop is only to take pressure off the circlip not limit travel.
    23,985
    Yup, certainly sounds like seals to me Dusty. It may have nicked a seal edge when it popped back . As an aside I've had that happen on a Classic car when driving down the road but it was the brakes !!
    Is the pushrod at the slave adjustable or a fixed length ? I've had them where I've found the pushrod wasn't the correct length so it bottomed out on travel before fully depressing the clutch ie not moving the cyllinder inside the slave far enough back at it's starting point. Like the push rod allows only 1.5" travel when you need 2" a longer pushrod fixes the clearance issue providing it doesn't bottom the slave out ( internally) the other way.
    Northants
    1,691
    223
    Dusty is offline
    The slave isn't moving at all. There was a trace of fluid on the wrong side of the seal so I replaced that.
    I could replace the seal in the master but I am so fed up with it I am inclined to buy new from CBS. This requires a new pipe which means that the whole lot is new.
    Given that the clutch didn't feel heavy for the few dozen miles I've driven the car, will a larger master be an improvement?
    Thanks for the replies so far.
    23,985
    Nope , larger m/c will make it heavier ( more fluid moved at lower pressure).
    Northants
    1,691
    223
    Dusty is offline
    I've gone a replacement of the same size.
  1. Lockheed clutch master cylinder pipe thread size?
    By ratwing in forum Tech Discussion
    Last Post: 06-06-2012, 11:02
  2. clutch/brake master cylinder
    By hotrodguy in forum Stuff - WANTED
    Last Post: 04-07-2010, 10:55
  3. Clutch Master cylinder identification!
    By heathy12 in forum Tech Discussion
    Last Post: 29-12-2009, 16:39
  4. 39-46 Ford Master Cylinder
    By RustyA in forum Stuff - WANTED
    Last Post: 21-07-2009, 10:04
  5. What clutch master cylinder?
    By Mudgie in forum Tech Discussion
    Last Post: 25-05-2009, 20:32
