Coil ohm test conclusive??
Results 1 to 9 of 9
    Stroker Kustom Jim's Avatar
    Bath
    5,044
    2708
    Kustom Jim is offline
    LightbulbCoil ohm test conclusive??
    Howdy,
    Was timing up the mill yesterday and my non dial back, simple strobe light went off as I revved it up!?
    Tickover runs sweet as a nut, rev quickly and ok, hold revs past 1500 and strobe light goes mainly off and starts backfiring.
    I did the ohms test on MSD Blaster 2 coil (second hand, at least 15 years old I think and only just put in to service).
    It should be...
    Primary 0.7 ohms. I got 1.5
    Secondary 4.5k. Can't remember lol will update later
    Anyhoo, before I go back to it this sunny morning is this a conclusive test that it is good/bad?
    I know nowt about ohms and just going through this voodoo motion.
    Engine also has a used MSD6AL, worked fine before and a recently serviced contactless distributor? (I will do the recommended msd box test too)
    Many thanks
    Jimbo
    Carroll Shelby
    23,278
    https://www.hotrod.com/articles/choo...ignition-coil/
    If I'm not sure what a coils up to I normally rig it up off the car and look of the quality of spark. There's another Pertoronic video about on how to do that .
    Have to say all I keep hearing about with MSD is failed components. not first hand experienc ethough.
    Herts
    4,601
    198
    WB54 is offline
    what you describe is indicative of either coil or leads breaking down. Work out the values of the coil and test the secondary again, then test your leads. Maybe run the motor in the dark and look for any arcing that's a sign the leads insulation is breaking down
    Bath
    5,044
    2708
    Ok,
    Just redone the coil test
    Primary standard 0.7. I now read 1.2
    Secondary standard 4.5k. I got 10.4k
    Did the MSD box test - flashed the distributor harness and no spark, there should be one, just a weird mouse squeak from the box. Unfortunately to double check it says I need another coil to prove one or the other.
    The leads are almost new but will have a look!
    Jimbo
    longroof society member yellacar's Avatar
    Jun 2009
    birmingham
    357
    32
    yellacar is offline
    hi guys
    Not all timing lights work with MSD 6AL boxes because they are dual spark, if you research in to this you will find loads of conflicting answers as to which timing lights work with said boxes. some say the cheaper the timing light the better as it can only read the dual spark as one. some say expensive snap-on lights work but others say not so it seems to depend on what light you have, apparently some expensive digital ones are too sensitive and get confused with the twin spark of the MSD unit, believe me I spent hours and a few bob on cheap timing lights (that broke in a very short time) researching this topic.
    My conclusion was to buy a innova 5568a timing light cost me about £80_£85 and yes it dose work with a MSD 6AL ignition box. this may not be your problem but I hop it helps and helps others that are suffering the same problem.
    Cheers Ian
    Bath
    5,044
    2708
    Hi Ian,
    Yeah, I did buy a dial back light a coupla years ago only to find it was pants with the MSD box. I use the old light I bought in the 80s lol it's almost just a bulb with wires but does the job although now you've said it the timing does have a weird double take flash discernible to the eye.
    I'm gonna get another coil after me hols and give it a all another go.
    Dec 2012
    winsford
    343
    221
    boblester40 is offline
    Multi spark is only active sub 3000 rpm , so if checking total timing over your advance rpm it should not effect the gun .
    If your lights going off and you are getting back firing that suggests you are loosing the spark.
    Is the 6al wired correclty , what trigger do you have ?
    Whats the 6AL rpm limit set at ?
    Bath
    5,044
    2708
    Howdy.
    OK, it's running the MSD6AL with 6000 chip.
    It was running fine inside car before engine bay fire.
    Ditto the Pro Billet contactless distributor. All new parts fitted.
    Replaced 750 carb with a refurbed 800.
    Running it can be adjusted to give a good 12-15 reading on the exhaust thingybob.
    Like I say before the bonfire it all ran sweet as a nut.
    I will double check all the wiring.
    The only unknown is the coil as it was an old thing I had in a box for 15 years and it was old then - I have never used it till now so unsure if it was just passed on as crap to me. And in the interests of future reliability I'd probably renew it anyhoo.
    cheers
    Jimbo
    Bath
    5,044
    2708
    Ok, it's good to post the resolution.
    In the end I swapped out the coil and bad box, redid a poor coil HT lead, redid timing blah blah and it was mucho better but no cigar.
    Rechecked the new old carb to find the primary jet springs on the extreme setting. Swapped in some orange stockers BOOM!! Sorted. Purrs like a lazy lion, roars like a tyrannosaurus!!
    Then blew the fecking oil pressure pipe off the block showering everything with hot Valvoline
    1. 0-30 ohm fuel guage - 53mm - where to get ??
      By Chevy Chaser in forum On Topic
      Last Post: 29-05-2014, 22:57
    2. Replies: 16
      Last Post: 25-10-2010, 09:04
