Coil Testing
Results 1 to 10 of 13
Thread: Coil Testing
    Aug 2009
    South Cheshire
    1,254
    59
    RockabillyBilly is offline
    Coil Testing
    RV8/Auto/Pertronix ignition/Flamethrower coil.
    Hellooo. The Coupe broke down the other week and, because it 'petered out' rather than cut out 'Doodle Bug' style, I assumed it was a fuel issue. After 10/15 minutes, it started up, ran for 10 minutes, broke down, left it for 10 minutes etc etc until I got home. However, my Hot Rod buddies thought it was electrical. As always, I think they were correct. I replaced the coil and went for a 15 mile drive with no problems.
    Is there a way of bench testing the coil with things a 59 year old Hillbilly would have in his Shed ie; no Multimeter etc, just a bit of wire, a bulb and other stuff that's not relevant to this thread.
    Thanks nicely.
    Sep 2011
    Kings Lynn
    2,869
    332
    brading is offline
    Not really Billy. Even if you bench tested it with a multimeter it might show it is ok where as when it run on a engine for ten minute an tested it would show that once it had got warm that it is breaking down internally.
    Gym Junkie chrisvs's Avatar
    Jan 2011
    Hitchin
    6,213
    125
    chrisvs is offline
    Put the coil back on again, if it breaks down then its pretty certain the coil is faulty.
    Paradise is full of idiots who believe it exists - Georges Wolinski
    I Think Therefore I Am - René Descartes
    www.nothingbeingadvertisedhere.com
    Oct 2012
    surrey
    619
    2
    was it mounted upright or on its side by chance....it could overheat if not fitted upright
    neil
    Keep on Trucking... F100Jay's Avatar
    Apr 2015
    South wales
    535
    11
    130
    F100Jay is offline
    Quote Originally Posted by neil still building it View Post
    neil
    I did not know that.
    Dec 2010
    Near Canning Town, London
    1,622
    1711
    Taxirod is offline
    Some years ago I had a blown Rover in a 32 roadster, every summertime when it got hot it would cut out, then start easily after cooling off.
    Eventually I realized that by mounting the coil to the head, it was just getting too hot sometimes. Moved it away from engine to solve problem.
    Aug 2009
    South Cheshire
    1,254
    59
    Thanks all. chrisvs; I was going to do exactly that but, living where I do and knowing the luck I have, if it were to break down, it would do it on a bend or some such inappropriate place but, good idea though and it would certainly eliminate it. Neil; I didn't know that either but, it's upright on a mini exhaust bobbin located near the nearside front, about where the sump joins the engine.
    Thanks for the replies everybody.
    Aug 2009
    South Cheshire
    1,254
    59
    Forgot to ask; Do I have to have a Pertronix Flamethrower coil or, would a normal 12v coil be ok to use with my Pertronix electronic ignotion?
    Thanks.
    Jan 2011
    Hitchin
    6,213
    125
    chrisvs is offline
    Quote Originally Posted by RockabillyBilly View Post
    Thanks.
    The Pertronix Flamethrower probably has a much higher HT voltage than a standard coil, some go up to 60,000 Volts.
    Aug 2009
    South Cheshire
    1,254
    59
    Thanks chrisvs; Excuse my ignorance but...er...does that mean I can use a 'ordinary' 12v coil or do I have to use a Pertronix Flamethrower coil?
    Thanks.
    1. Testing front coil springs
      By sidspop in forum Chat
      Last Post: 10-04-2014, 21:50
    2. Testing a coil
      By Hemi Bucket in forum Tech Discussion
      Last Post: 02-05-2011, 10:24
    3. Testing a coil /ignition module ?
      Last Post: 01-05-2010, 09:09
    4. Coil Overs
      Last Post: 06-07-2009, 08:52
    5. just testing
      By zefa46 in forum Chat
      Last Post: 11-06-2009, 18:37
