Cooked my 351 - New engine/heads?
Results 1 to 10 of 15
    I'm a newbie !
    Jun 2016
    Lewes, East Sussex
    10
    WillNash is offline
    Hi All
    I'm new here, any pointers most welcome.
    I have a 1988 E250 Extended Ford Econoline converted from the factory to a camper. It has regularly overheated and I have tried various things to fix that, most recently replacing the radiator which was clogged up with muck. Last week I got stuck in a bank holiday jam and properly cooked it to the point where the front grill started to melt/buckle. I have definitely blown the head gasket so at very least will need to take the heads off, the engine still runs, there are no obvious signs of damage from the outside but I fear that there will be proper damage internally, the rest of the van is sound and in good condition for its age. I would really like to get it working reliably so am thinking that rather than spend money replacing bits only to come back to the existing overheating problem I could stick a like for like reconditioned 351 engine in it, has anyone got any thoughts on this, suggestions on places to get a suitable engine, people who would be able to do the swapping (I'm in East Sussex), things to watch out for?
    Jun 2016
    Roswell, New Mexico
    791
    NMNeil is online now
    Overheating will possibly cause the pistons to expand beyond their limits scoring the cylinder bore, but until you take the heads off you won't know.
    If the bores are OK and the bottom end bearing aren't knocking you may get away with just a head gasket change.
    The most common cause of overheating on these engines is the fan clutch. Easy to check, if you spin the fan does it stop before it's completed one revolution?
    Sep 2014
    The north
    1,365
    1314
    nuggets is offline
    If you want a 351 fan I've got a couple here. Either fixed meat slicer or clutch
    Fixed one is handy for in town
    Oct 2012
    surrey
    630
    2
    rings could be toast too..get a compression test done to see ,before you strip anything and spend any money.....
    I'm a newbie !
    Jun 2016
    Lewes, East Sussex
    10
    WillNash is offline
    Arranged to take out the engine next week to see what's what. The fan does spin freely, clutch is gone. After reading up on a few forums I'm thinking of replacing it with an electric fan at the same time as getting the engine sorted. Any tips on Electric Fans?
    12,975
    i'm sure real steel did a crate 351w at good money. just swap your bits over and away you go.
    Lower Kingswood, Surrey
    3,426
    185
    Mad Mark is offline
    Quote Originally Posted by WillNash View Post
    Yes, the bigger the better! I used a Mr Gasket one from Real Steel and apart from a little cock up be the painter, it's been working great for 12 years!
    8,947
    1770
    blackpopracing is offline
    Volvo 760 series fan - fantastic pulling power and 2 speed to boot. Very cheap from scrappys (get relay box to go with it if you want to use both speeds) and flat fixing flange all round makes it a snip to fit.
    Jun 2016
    Roswell, New Mexico
    791
    Try for an adjustable controller to set the temperature that will turn it on, and if possible a manual override switch in case the controller quits.
    Aug 2011
    surrey
    1,662
    19
    robo1 is offline
    I would stick with the mechanical fan and original shroud, its all designed to work in far higher temperatures than we have here without issues. If the rads good, all the collant pipes are sound and the fan is working properly all will be well. Leccy fans just dump another 30amps on the alternator when they are running .
    Bob
    I onlay edet to korrect bad smeeling mistaces
  1. Ford 351 cleveland engine parts
    By jonny z in forum Stuff - WANTED
    Last Post: 05-10-2011, 18:24
  2. Ford 302/351 w engine parts wanted
    By cougarv8 in forum Stuff - WANTED
    Last Post: 25-09-2011, 22:33
  3. New Engine
    By insaneron in forum Chat
    Last Post: 25-11-2010, 21:43
  4. Proper new engine break in 101..... some helpfull tips
    By Dr.Dee in forum Tech Discussion
    Last Post: 14-09-2010, 04:21
  5. Engines and wheels for sale,new ally heads
    By poproadster in forum Stuff - FOR SALE
    Last Post: 14-09-2009, 17:55
