coolant leak help
Results 1 to 5 of 5
    Rods 'n' Sods Junkie stevo1980's Avatar
    Jun 2015
    feltham middlesex
    125
    9
    5
    stevo1980 is offline
    coolant leak help
    Hi, chevy 350 coolant leak on cooling down only from thermostat housing.
    Dont leak whilst running or when hot, just once you have turned engine off and left it for a while.
    I checked Thermostat which was stuck closed, worked it free and tested it in boiling water and started opening and closing ok, refitted and sealed a new housing I had laying around but still leaks...I have a new thermostat coming today but just wondered if could be something else?
    23,537
    Yup loads !! I've had acouple of mates caars with ongoing problems .One was traced to a warped NEW aftermarket thermostat housing . I've had to buy 4 housing foir my engine to get a straight one as well Also ckeck bolts are correct thread especially if the protrude into water jacket. A metric bolt will tighten into a UNC thread but water will wick up the gap in the thread.
    9,140
    1772
    blackpopracing is offline
    What Kev said. My chrome one leaked like yours - it does leak when hot but evaporates off so you cant see it. Sealed it a couple of times and the checked it with a straight edge. Like a banana!!
    Ground it flat on a linisher but it still leaked.
    Bought a new one with the rubber O ring in and no more leaks.
    Jun 2015
    feltham middlesex
    125
    9
    5
    ah ok great, I did try and swap the housing with a rubber oring but still leaked, will have try a better quality one I guesse and check the bolts too. Thanks for the advice
    9,140
    1772
    I changed mine to studs, Glue the studs in with Loctite bearing & stud fix, this seals them & stops them turning. Then just use nyloc nuts to secure. No more manky bolts in the water jacket. Get a straight edge to check your housing is flat, the O ring ought to cure most of it though. A little RTV sealant as well might help if the surfaces are not in good condition.
    1. Gm turbo 350 trans leak
      By mikeyboy in forum Tech Discussion
      Last Post: 02-12-2011, 11:43
    2. summer coolant
      Last Post: 12-05-2010, 07:09
    3. SBC oil leak, possible rear crank seal?
      By Britdragster in forum Tech Discussion
      Last Post: 21-03-2010, 19:31
    4. help ..oil leak somewhere? 67 chrysler
      By jimo62 in forum Tech Discussion
      Last Post: 12-03-2010, 19:36
    5. Infer-red leak detector "SOLD"
      By Zody in forum Stuff - FOR SALE
      Last Post: 02-06-2009, 20:28
