CORTINA Mk3 IFS AGAIN !
Results 1 to 4 of 4
    Aug 2009
    northill
    239
    306
    460coupe is offline
    Hi all
    When i fit a 'x' member is it mounted level with the chassis rails (they are level front to rear kick up). my main concern is caster angle, I presume this is taken care of by 'A' arm position and uprights, probably a daft question but i'd sooner be safe now rather than later.
    cheers guys JOHN R
    Flange Dealer Paul G's Avatar
    Derby , UK
    642
    57
    Paul G is offline
    The clip sits level , the bolt that mounts the top arm is set at an angle of about 3 degrees, from memory. If you measure the distance up from the bottom arm bolt hole to the top arm bolt hole at front & rear of the clip, you'll find that the dimension at the front is slightly bigger.
    23,576
    Plus of course the chassis needs to be set at the finished ride position when you instal it ,if you put it in with the chassis level and then jack the rear you'll lose your caster.
    You can also fine tune the caster by setting it on the lower tie bars.
    Aug 2009
    northill
    239
    306
    460coupe is offline
    cheers guys, I was fairly confident on both points,but as its my first build its always nice to be sure. JOHN R
    1. 1972 Ford Cortina Mk3 Super Speed
      By CraigR in forum The Showroom
      Last Post: 03-02-2012, 20:54
    2. mk3 cortina ifs
      By 460coupe in forum Tech Discussion
      Last Post: 20-09-2010, 21:35
    3. Cortina Mk3 axle
      By Trike the bike in forum Stuff - WANTED
      Last Post: 09-08-2010, 09:15
    4. Cortina MK3 NOS Door
      By UK RUSS 1960 OLDS in forum Stuff - FOR SALE
      Last Post: 27-02-2010, 12:51
    5. 4 Top & bottom ball joints for mk3/4/5 Cortina
      By Hemi Bucket in forum Stuff - FOR SALE
      Last Post: 28-10-2009, 22:50
