cortina steering column
Results 1 to 5 of 5
    keynsham, bristol
    189
    nigel h is offline
    I've got a cortina steering column to use with my IFS. looked at portland pops biva build thread and he has used the same, great thinks me.
    How wrong can I be his uses a shaft that is 19 mm across, mine is only 16mm across. We are both using the triangular ends to the column and using part of the round shaft.
    Now I cant find any shafts that are that big , so does anybody have any ideas how to join the 16mm shaft to maybe 3/4 inch dd shaft?
    Failing that I could look around for another column, dont really want to that. cant afford a new shiny one either.
    I'm stuck Help
    13,150
    if the triangle bit is the problem then rally design do a uj thats triangle one end and splined the other. and the splined shaft and sleeves to suit.
    keynsham, bristol
    189
    nigel h is offline
    cheers for that any idea how many splines is it 36? Gonna gets some of the joints this w/e hopefully
    13,150
    not sure on spline count, but whatever mk1/2 escorts were. i think most older english fords up to the 80's were the same spline. so should cover cortinas. neil.
    keynsham, bristol
    189
    nigel h is offline
    cheers
    1. tri chevy steering column
      By hotrodguy in forum Stuff - WANTED
      Last Post: 17-11-2009, 09:21
    2. mk1 cortina steering box
      By tappets in forum Stuff - WANTED
      Last Post: 11-10-2009, 02:12
    3. pop rear spring/bones/ steering column/box wanted
      By sqweaka in forum Stuff - WANTED
      Last Post: 24-09-2009, 14:49
    4. Mini steering column
      Last Post: 03-09-2009, 07:14
    5. Steering column???
      By Throttledwife in forum Stuff - FOR SALE
      Last Post: 01-09-2009, 23:55
