Dellorto twin 40 set up
Results 1 to 10 of 19
    Official RnS Addict yorkster's Avatar
    Jul 2009
    leicestershire
    572
    42
    yorkster is offline
    i need to set the carbs up on the alfa motor,it starts ok and runs good when its above 1500 to 2000 rpm but it coughs and splutters on take off,theres that many adjustable jets on them im scared to start messing with them.anybody got a diagram or know how to set them up or even which jets are the idle mixture ones?
    cheers
    Glasgow,Scotland
    2,123
    german8rcoupe is offline
    Re: Dellorto twin 40 set up
    If they are DRLA's they should be fairly easy to tweak.
    Basic settings first.......remove linkage and back idle cam right off so throttle plates are closed. Wind them both out evenly about 3 full turns. the mixture screw are the ones on the side of the carb inline with the venturis. Screw them all the way in GENTLY, then back them out 2.5 turns. Check the accelerator pump jets are scooshing fuel in when you work the throttles.
    Start it up working the throttles manually, you need good co-ordination for this, blip it until it is warm. If it will idle, then get a length of tubing about 10mm id and strick one end in your ear and the other one in each venturi.
    By listening to the amount of sucking going on you can tune the throttle openings to balance the carbs. Once balanced. connect linkage and check it opens both carbs simultaneously. Read the plugs after a bit to suss out mixture settings.
    I am assuming it's a flat Alfa engine with down draught Dells fitted although this way may work with other types.
    Jul 2009
    leicestershire
    572
    42
    yorkster is offline
    yes its an alfa engine but the carbs are side draught DHLA's i think,ill try the rubber hose trick though,i might try to adjust the idle screws bottom them out counting the turns take them out and blow them out with the airline,replace and try setting them.
    cheers
    23,747
    The last time I worked on Dells ( downdraughts on a Rover ) I was surprised to find that they specify 4 turns out as the baseline mixture setting?
    Jul 2009
    leicestershire
    572
    42
    yorkster is offline
    i think i need to get a book then,its no good guessing it could end up worse than it is now.
    thanks again
    23,747
    Jul 2009
    leicestershire
    572
    42
    yorkster is offline
    exellent thanks v much,i've spent the last two hours searching the net for something like that and got bugger all!!
    thanks again
    23,747
    I was trying to find an online tuning article. I'll mail a mate as I think he found one awhile back.
    Jul 2009
    leicestershire
    572
    42
    yorkster is offline
    right then i've ran it today and it seemed a bit better,so i took it for a quick drive round then ran out of petrol!! after it fired up again it was still ok,theres a very slight hesitation but nothing like before so im thinking that maybe running petrol through the carbs may have broken down any old residue etc that was in the jets?
    anyways itll get me to the mot as is and then i can set the carbs at my leisure when i get the instructions.
    thanks again fellas.
    Glasgow,Scotland
    2,123
    Try and get a hold of the Dell'orto Superformance manual if you can.
    I have one from my VW days and it is very good. I.ll see if it covers the DHLA too.
    1. fiat twin cam
      By duffbeer in forum Tech Discussion
      Last Post: 29-04-2010, 22:11
    2. Dellorto DHLA throttle linkage
      By Hole Shot Pop in forum Stuff - WANTED
      Last Post: 16-04-2010, 12:27
    3. twin afb / edelbrock carbs...
      By dualquads in forum Stuff - WANTED
      Last Post: 24-02-2010, 12:31
    4. twin post ramp
      By hotrodguy in forum Stuff - FOR SALE
      Last Post: 15-08-2009, 17:45
    5. twin cam
      By badobsession in forum Stuff - WANTED
      Last Post: 01-07-2009, 00:13
