DIY Headers
Likes Likes:  2
Results 1 to 10 of 18
Thread: DIY Headers
    Jul 2011
    West Mersea
    3,368
    58
    Big Joe is online now
    DIY Headers
    I'm thinking about making my own exhaust headers/six branch manifold for my Zodiac (straight six engine)
    Ive found these bends on the web and they look like they should do the job and they do tube to match
    https://www.fhbrundle.co.uk/groups/2...le_Elbows_Tees
    My battle plan is to make them on the bench using a spare head as a jig (yes I have one)
    The hard bit is that the MK3 CCZ has a half round recess in the head that the original pipe manifold fits into, so I need to make up D blocks with steel plates welded to them (this is how its usually done on these engines) or maybe use one long half round bar to fill the half round recess.
    I havent measured the diameter accurately but it looks to be 1 & 3/4 inch and I cant find bar in that diameter.
    Any thoughts?
    Welding Guru
    Apr 2012
    Runcorn Cheshire uk
    687
    529
    30
    weldtech is offline
    The finished manifold will be quite heavy using those bends, have you looked at mandrel bends on ebay. There are loads on there that might be an option
    Jul 2011
    West Mersea
    3,368
    58
    Quote Originally Posted by weldtech View Post
    Thanks, I didn't think about the weight I will look at the eBay bends
    nottafukinchancingham
    8,041
    62
    Torment is offline
    Whengparts may be able to help with flanges.
    57 chevy wagon.
    540cui altered.
    Stroker Kustom Jim's Avatar
    Bath
    5,343
    2783
    Kustom Jim is online now
    I converted a 1600 four branch to fit my MKII Consul (1979 ish) By god what a job making up the half round bits for the heads was. Fortunately I did them at work. If I had my time again I'd find a way to use the stock manifold bit that bolts to head hot diggety no doubt.
  8. Likes mygasser liked this post
  9. #6
    13,864
    Quote Originally Posted by Kustom Jim View Post
    that's what i'd do too, it's already the right shape to do the job so no point reinventing the wheel.
  10. #7
    Jul 2011
    West Mersea
    3,368
    58
    I did think of that, but the stock manifold is a tube (I'm sure you both know that) I did think of using a steel bar of the same diameter and boring the holes in that....
  11. #8
    Jun 2009
    Rayleigh Essex
    3,189
    289
    trevd is offline
    can you not use the original manifold tube and open up the original holes and bore them all the way through to take tubes? i could make the D parts for you but it would be cheaper to modify what you have and less chance of leaks.
  12. #9
    Jul 2011
    West Mersea
    3,368
    58
    Quote Originally Posted by trevd View Post
    I did think about that but the steelwork is nearly sixty years old and just a little bit corroded. I'm thinking along the lines of using a length os one and three quarter inch bar and boring (or having an engineer shop bore) the holes for the ports and welding the tubes onto that.
    The reason that I was thinking about the D blocks and plates is because that's how it was done in the old days..
  13. #10
    13,864
    on the plus side if you went for the 'd' blocks you'd only need to buy a round bar half the length to start with, lol.
