Dual circuit master cylinder?
Likes Likes: †4
Results 1 to 10 of 18
    Grown up? Never!
    Norwich
    2,069
    35
    chaley is offline
    Morning,
    Iím looking to replace the mk4 cortina servoíd master cylinder with a non-servo 1.
    Basically the new manifoldís vacuum take off is useless, is got the pull to adjust the timing, but only if you donít hook up the brakes. So I need to ditch the servo, it will also give Tetanus another inch or so for ground clearance as well so win win. Oh and the servo is a bit shagged anyway
    The set up at the moment is.
    Under floor mounted mk4 servo master cylinder.
    Cortina m16 disc front brakes.
    Cortina mk4 rear brakes.
    Iím really hoping for a bolt in option or Iíd go for a bias pedal box, but itís not a race car, I only want it to stop properly
    Iím thinking of running a ford inline brake compensator thingy to stop the rears locking up first.
    Iím not sure where to start with sizes of bore etc, so any help would be awesome.
    Cheers folks,
    Chaley
    Tetanus
    22,830
    You won't get decent line pressure unless you go bias box . Bias box with twin 5/8ths will do the trick.
  4. Likeschaley liked this post
  5. #3
    Grown up? Never!
    Norwich
    2,069
    35
    chaley is offline
    Bugger!!!
    Thanks Kev, not the answer I wanted, but at least I now know it’s the right way to go.
    Anyone got a cheap on for sale
    Chaley
    Tetanus
  6. Remove Advertisements
  7. #4
    22,830
    You can get the bits to build a custom one on ebay for around the £30-40 mark. I used the measurements avaialable on the Wilwood site to custom build a couple of mone.
  8. #5
    Herts. and ahead of Larry :)
    2,581
    34
    chevy2 is offline
    Have you thought about fitting an alternator that has a built in vacuum pump on the back?
    Plenty of factory stuff runs them
    No need to alter your brakes if so....
  9. #6
    12,517
    Quote Originally Posted by chevy2 View Post
    Di transit had these fitted, you need an oil feed and return though. Lots of diesels had small belt driven vacuum pumps.
    Neil.
  10. #7
    2,581
    34
    chevy2 is offline
    Neil.
    I thonk Corsas also run them Neil,
    May be a bit more compact than the transit one but with no doubt less amp output.
  11. #8
    Grown up? Never!
    Norwich
    2,069
    35
    chaley is offline
    Thanks chaps,
    I think I’ll go with the bias box.
    I’ve just seen the price of a replacement ‘tina servo and ouch!
    The bias box also gives me matching pedals for a change and if I fit it with flexies before the hard line and can make it adjustable, so Liz can drive Tetanus with only a bit of tinkering.
    Win win!
    I’ve also got one of those tiny denso alternators and it would be a shame to change that out.
    But it all goes in the memory bank for later.
    Chaley
    Tetanus
  12. #9
    12,517
    you could use one of these under the floor with your existing pedal https://www.rallydesign.co.uk/produc...oducts_id=4045
    or for matching pedals either of these on the floor, maybe with the cylinders through the lower bulkhead?
    https://www.rallydesign.co.uk/produc...ducts_id=13604
    https://www.rallydesign.co.uk/produc...ducts_id=24101
  13. #10
    Grown up? Never!
    Norwich
    2,069
    35
    chaley is offline
    Cheers Neil,
    That last one was the one I was looking at, but I need a cable clutch one.
    Chaley
    Tetanus
    1. WTD Wilwood dual circuit master cylinder
      By pitsspecial in forum Stuff - WANTED
      Last Post: 09-03-2013, 20:32
    2. Single or Dual Circuit Master Cylinder ?
      By WB54 in forum Tech Discussion
      Last Post: 31-08-2011, 21:47
    3. 7/8th or 22mm Dual Circuit Master Cylinder
      Last Post: 16-08-2011, 15:42
    4. Dual circuit Master cylinder.
      By 50AD3100 in forum Stuff - FOR SALE
      Last Post: 03-04-2011, 04:36
