eaton m45 supercharger on ford x flow?
Results 1 to 5 of 5
    Official RnS Addict shorty's shaker's Avatar
    Oct 2009
    exeter
    569
    shorty's shaker is offline
    eaton m45 supercharger on ford x flow? friend of mine is after any info ref this sort of conversion if doable with the eaton
    Bridgwater
    727
    37
    scooder is offline
    Course its doable. But the problem I feel will be the pistons, and the compression ratio. Lots of times folk will use a "de compression plate" To lift the head up and away from the pistons, and lowering the comp ratio. In my mind this is a **** idea, and counter productive. Sure it lowers the comp ratio, the idea being that you can bung more pressure in with less detonation risk. The problem is thus. when you move the head away from the entire piston crown/dish you loose your squish or quench area, twix the piston and the head surface. When you loose this squish/quench the chamber becomes MORE prone to detination. See? Counter produtive. Dont know if you can get them, but if I were doing it, I'd want a lower compression ratio piston (deeper dish with a crossflow) that kept the top edges of the piston right up the top where they should be for good tight Quench.
    Martin.
    The rest of it is brakets and pulleys and ratios and manifold. Do that in a sandwich brake
    Nov 2012
    KIRKBY WOODHOUSE, nottinghamshire
    1,947
    69
    cc41memorylane is offline
    I fitted a shorock c75 blower to a over bored 1500 triumph spitfire motor which i had in my hot rod minor. it ran fine with no problems.
    23,547
    Quote Originally Posted by scooder View Post
    Martin.
    Not forgetting what the plates do to rocker geometry , just like skimming the head too much for the other extreme.
    May 2010
    bromsgrove
    748
    61
    steve1275 is offline
    Nuttier than squirrel shit
    1. eaton m45 supercharger
      By vinnythespud in forum Stuff - FOR SALE
      Last Post: 14-11-2011, 17:07
    2. ford x flow remote oil filter or any parts
      By shorty's shaker in forum Stuff - WANTED
      Last Post: 01-08-2011, 18:18
    3. Ford X flow cam
      By jnh in forum Stuff - FOR SALE
      Last Post: 30-06-2011, 14:22
    4. supercharger for ford 302
      By dek in forum Stuff - FOR SALE
      Last Post: 26-05-2011, 08:13
    5. Brand New MagnaCharger (eaton) MP112 Supercharger
      By andrew_37ford in forum Stuff - FOR SALE
      Last Post: 22-01-2011, 06:29
