engine/box angle 350/350 chev
Results 1 to 8 of 8
    Rods 'n' Sods Junkie 100ev8's Avatar
    wolves
    437
    66
    100ev8 is offline
    is there a correct angle to mount a sbc engine and th350 box ? where do you take the level from ?
    any tips ?
    cheers rob
    Mid England Retrims. stumpy's Avatar
    united nations of birmingham
    350
    302
    stumpy is offline
    i believe its 3 degrees down on gearbox output and 3 degrees up on diff flange. but i standd to be corrected.
    Www mid-england-retrims co uk.
    350
    302
    stumpy is offline
    cromwell tools do a 360 degree gauge that has a magnetic foot , best way is to make sure the car/chassis is 100% level , set the axle first to 3 degrees up by setting the angle finder on the diff flange. then do the same to the gearbox , but 3 degrees down. pretty simple really.
    cromwell tools link to said finder http://www.cromwell.co.uk/quicksearc...h=angle+finder
    nowhere
    7,055
    2407
    nobody is offline
    i set mine with the carb level.with the car at ride height
    this puts the engine at about 3 degrees as stumpy says.
    put the angle finder on the end of the gearbox then set youre axle to suit.
    unless youre axles already in place with no movement then you need to set engine/box angle to diff angle
    west midlands
    2,819
    259
    stevie.t is offline
    set car at ride as said, i then take my measurments from the manifold level left to right 3ish degrees down at the back, imo its not that critical as long as its close if anyone saw ancscious arnold id say he's car throws a lot of therorys out the window
    I'm a grown up member now ! kryptonite67's Avatar
    Sep 2009
    ayr ontario aer kid!
    88
    2
    kryptonite67 is offline
    it all depends on vehicle ride height too, the engine will usually be 3 degrees as this is the angle most intakes are cast at so carb is horizontal, if you are running a car low then the axle will be any where from horizontal up to 3 degrees, if you are setting up a truck with a lift kit or gasser style high rear end then these angles go out the window, as long as the two ends are not facing down (or both facing up!) then it will be ok . We set 99% of our axles on hotrods with no more than a 1/2 to 1 degree up and never get any vibrations, i think some of the big names in the usa have guides on their websites like strange and bears.
    350
    302
    stumpy is offline
    if i remember correctly its not vibration that your trying to eliminate with the correct angles , its to do with the roller bearings in the prop connectors , by putting the axle 3 degrees up and gearbox 3 degrees down , under normal running all the roller bearings or needle bearings in the prop unniversal joint are active under the same loadings and lubricated correctly. vibrations are down to unbalanced props. as stated earlier your vehicla must be at the correct final ride height , stance to be able to set it correctly.
    watford
    1,109
    firebird68 is offline
    The combined angle should be no more than 7 degrees. Also on coil spring rear ends the angle can be less as there is no wrap -up as found in leaf springs.
    1. project angle box!!!
      By sickntwisted in forum The Garage
      Last Post: 21-08-2010, 20:58
    2. Pinion angle
      Last Post: 22-04-2010, 18:26
    3. 55 Chev
      By ROCKIN WOLEY in forum Chat
      Last Post: 16-04-2010, 19:30
    4. Ex-AA 2500kg Car Trailer with low loading angle
      By JAY PS in forum Stuff - FOR SALE
      Last Post: 12-03-2010, 22:29
    5. Correct angle
      By bootlegger in forum Tech Discussion
      Last Post: 25-02-2010, 12:06
