Engine Clearances
Results 1 to 10 of 11
    Jun 2009
    Ayr Scotland
    676
    44
    bigdavy is offline
    Engine Clearances
    Hi guys,
    I'm currently helping a mate fit a zetec engine into a spitfire and i have a query, we have the engine about where we need it & mounts etc look about right but it's very tight at a couple of bits.
    Main question is what's the opinion re clearance minimums? At the front crank pulley its only about 4mm clear of the steering rack (centre area non moving) and similar clearance at the steering column. I'm just not sure if it's enough, other than the standard rotation of crank nothing should move but i'm not quite convinced
    Obviously we can't just raise it easily without causing multiple other issues with alignment etc. so whats your opinion, will we get away with it with minimum clearance or is it just not enough?
    Rods 'n' Sods Junkie DEVONMAN's Avatar
    Oct 2010
    Croydon
    378
    7
    DEVONMAN is offline
    It really depends on how stiff the engine mounts are but 4mm clearance is a bit on the tight side. The engine will move towards the driver side (ie steering column) under acceleration and the 4mm will reduce accordingly. Also if a mount breaks or deteiorates with time the engine could move and jam the steering column.
    Cheers Denis
    Jun 2009
    Ayr Scotland
    676
    44
    bigdavy is offline
    Thanks Denis, hadn't thought about the engine moving sideways under torque, thats a great point. Do you have any thoughts about a minimum amount of clearance?
    Nov 2009
    stourport
    5,531
    7
    beach57 is offline
    Switch the engine mount to either solid or poly ,4mm bit close
    Nov 2009
    stourport
    5,531
    7
    beach57 is offline
    Move engine to the left .
    Jan 2010
    london
    324
    john tudor is offline
    If you cant move engine back or sideways how about fabricating a couple of stabiliser/tie bars( adjustable with poly bushes or teflon lined rose joints?
    never enough days in a hour!!!
    Rods 'n' Sods Junkie Fl@pper's Avatar
    Mar 2011
    Cheltenham Glos uk
    255
    7
    Fl@pper is offline
    to check mine I grabbed it and gave itm a good shake like I was trying to rip it out in a rage
    If it's clear for that then it's clear for 99% of anything
    You only get one lap of life so why not ride it Flat OUT !!!!
    Sep 2009
    plymouth
    809
    mike noble is offline
    ref pulley, dont forget to leave room to get the belt on/off
    Jun 2009
    Ayr Scotland
    676
    44
    bigdavy is offline
    Many thanks for replies, think we'll need to try & move it a bit. Any thoughts about a minimum clearance?
    nowhere
    7,044
    2407
    nobody is offline
    hi davy
    can you not put urethane mounts in.the type fitted between a inner and outer sleeve
    that way there is not frontward movement at all and sideways would be max 4 0r 5mm if ever they failed which is unlikely.
    pop im doing has 5mm between the blower belt and rack and about the same between headers and steering tube between uj,s.
    with rubber type mounts id say about 15mm all round as they tend to move a lot more
    1. DIY Engine Turning
      By Mark H in forum Tech Features
      Last Post: 22-01-2010, 11:45
    2. Engine thats been sitting ?
      Last Post: 07-05-2009, 16:07
    3. SBC Engine mounts
      Last Post: 05-05-2009, 12:59
    4. Anyone know who built this engine originally??
      By neil harris in forum Chat
      Last Post: 26-04-2009, 09:00
