Essex V6/Auto help needed...
Results 1 to 10 of 20
    Leicester
    5,696
    594
    bigyellataxi is offline
    Righto, I have been told today that when I converted the free leetah to an auto that as well as removing the spigott bearing from the crank and using the two washers for the flexplate, that I should have also used a spigott for the t/c...
    Can anyone either confirm or deny the above statement...??
    Really don't think I used a spigott (although it was about 5 years ago)
    If I should have and I haven't this would probably explain the noise I'm getting from in the bellhousing...!!
    Fueled by Jim and Luckies.
    complete knob..apperantly pompeypaul's Avatar
    winchester, uk
    617
    68
    pompeypaul is offline
    when i worked in the breakers yard i can't remember seeing any auto engine with a spigot bearing, i could be wrong though !!
    Banned
    Nov 2010
    BRITAINS FASTEST STREET LEGAL VAN HEAD QUARTERS
    4,329
    388
    Fordson Van is offline
    Spigot? not on the auto. Some converters have a short stub to help centre the fitting when bolting the converter on. All the flexi plates are machine centred for accuracy so they run true.Sounds as tho you may have a cracked plate or it has worked loose,the flexi to converter and flexi to engine should be thread locked when bolting up
  5. #4
    Bridgwater
    727
    37
    scooder is offline
    On some auto stuff I've fiddeled with, in the back of the crank where the spigot bearing for the manual box would be, was a machined chap, that looked like a big spigot bearing, but was steel so not a bearing. this was there to support the nose of the torque converter and to centre it properly. The only ones I remember properly was a precrossflow Corsair auto and Cortina Mk1. I havent played with lots of autos though, so it may not be the norm. I thought that all auto stuff would have it, for the reasons I stated earlyer. Obviously the converter dont turn in this support, it turns with it. Other stuff may have the snout of the converter that fits nice in the crank spigot hole, as in the snout o/d fits the spigot o/d. So if its ment to fit stright in the hole in the crank, I think yours should not be a problem(not fitting some thing when you went to auto), but if its ment to have the machined chap (snout adaptor, or what ever its called) to match the o/d of the tc to the o/d in the crank, then the converter may not be in true, and is off center, if you catch my drift?
    Martin.
  6. #5
    I'm a grown up member now ! hotrod1935's Avatar
    Nov 2011
    wakefield
    74
    14
    hotrod1935 is offline
    hi guy its dean, back from your other thread, not alway on here , however ,
    it not strictly speaking a bearing, its a spacer /locating ring that fits in the back of the crank where a spigot bearing would be, and there are two types early and late, depending on the size of you converter stub
    hopefully the imge below shows left early spacer( bigger diameter), middle later ( smaller diameter) and a manual spigot bearing right
    hope helps
    dean.m
    p.s they are like rocking horse poo! and a nightmare to remove without a puller.
  7. #6
    Leicester
    5,696
    594
    Hi all thanos for the replies... Dean now you come to mention it I am sure I did get one from the Capri Clinic I chucked the receipt out the other month...!!! Anyways gonna have a look at the flexplate tomorrow and if nothing is conclusive its all gonna have to come out for a looksee...
  8. #7
    Nov 2011
    wakefield
    74
    14
    hi guy
    now you mention it i thought we got all the bits together at roughly the same time, from same places, my trouble seems to be the engine was a manual and now its auto and i am suffering vibrations, i am told by a good essex expert i should have had the crank,f pulley and flex plate ( and pref t convertor ) all balanced together ! and in all honesty there is a big weight on the flex plate which may not be in the right place so may make sence!so over winter its all commimg out to be balanced.
    cheers dean.m
  9. #8
    Leicester
    5,696
    594
    Dean, I'm sure the flexplate can only go on one way as the bolt holes aren't equidistant...???
    I was certain that the flywheel on an Essex is part of the whole balancing deal, not sure about the flexplate etc though...
    I'll find out more tomorrow about mine...
  10. #9
    Official RnS Addict Johnny's Avatar
    cotes, leics
    930
    140
    Johnny is offline
    Many moon's ago I built the wife a willys truck on a scimitar chassis - it was a manual and I wanted a auto so I swapped it with a chap with a auto . I just bolted it up no vibrations or any problems , it was still in the car last time I looked
    O.F.F.O
  11. #10
    Leicester
    5,696
    594
    All sorted, once we had managed to get the damn thing on the wheel ramps I had borrowed (they kept slipping forward until I braced them off the wall with tube!!) tightened up the T/C bolts and found a bolt that was holding the spacer plate in place was just catching the T/C bolts, so it came out and was thrown down the road...
    All is now good, there is a video of it on facebook, just search for Guy Davenport (thinks it's 'public') if not can someone cleverer than me nick it off there for me...???
    1. Auto electrical help needed 97 firebird Transam
      By impalandy in forum Tech Discussion
      Last Post: 05-03-2011, 19:18
    2. Auto-electricians help needed: Towing electrics
      Last Post: 13-12-2009, 16:38
    3. help needed / rover auto conversion
      By farncombe pop in forum On Topic
      Last Post: 02-08-2009, 11:58
    4. Help needed with transport Cov to Brum
      By sidspop in forum Chat
      Last Post: 10-05-2009, 10:28
    5. lube help needed
      By sqweaka in forum Chat
      Last Post: 06-05-2009, 15:54
