Exhaust system help please
Likes Likes:  1
Results 1 to 6 of 6
    Jan 2018
    East Mids
    43
    33
    corned is offline
    Hi again folks.
    Today's question is about exhaust systems. Current set up is a stock Ford 292 Y-Block (1962 vintage, according to the engine numbers). It has been fitted with tubular headers and a dual 2.5" OD stainless pipe system - one for each bank. There's no crosspipe or anything like that. There are two huge Thrush rectangular boxes half way along (under the cab/body join) and then straight pipes out under the rear axle and to freedom.
    I'm not happy with the sound. Or rather, the tone. The volume levels are ok, but it just doesn't have that musical Y-Block tone. In fact, the pipes have a hollow digeridoo-like sound at the back. Very unsatisfactory. If you rev it up, you get the characteristic V8 sound, but at idle it sounds like a kid making a noise from a drainpipe by blowing down it.
    So - what can I do about it? I like the sound that Smithy's glasspacks give out. But the question is can I just replace the mufflers, and fit 2.5" OD Smithy's, or is the problem bigger than that? Are the pipes just too big, giving it that hollow sound? And what difference do the various lengths of Smithy's mufflers make?
    I tried removing the tailpipes altogether, but the booming in the cab with the muffler boxes dumping out direct under the bed was just too much to bear.
    I'm not sure how to tackle the problem, so I'm open to suggestions please.
    nottafukinchancingham
    7,959
    57
    Torment is offline
    Move the mufflers to the rear...?
    57 chevy wagon.
    540cui altered.
    Feb 2013
    uranus
    2,243
    ivanhoew is online now
    try 2 inch from the silencers to the back ? or even 1.75".
    Jun 2009
    Rayleigh Essex
    3,165
    286
    trevd is online now
    i have always found the mild steel sounds better than stainless, mild sounds deeper pitch. try using mild steel from the box to the rear.
  7. LikesKustom Jim liked this post
  8. #5
    Feb 2013
    uranus
    2,243
    had a quick look and this appears to b around a 180-200 bhp engine ? if so you could probably use a 1.5 inch pipe from the silencers to the back each side , using a couple of reducers,and maybe pick up a bit of low down torque and fuel economy too .
  9. #6
    Jan 2018
    East Mids
    43
    33
    corned is offline
    Thanks guys. This is what I'm thinking - those drainpipes are far too much for a relatively low-tune / low-compression motor. It's a later truck C2AE motor, so probably 160bhp new max.
    I like the idea of the glasspacks, but was unsure of the rest of the system. Now I know the direction I need to head.
    Much appreciated!
    1. Fuel System help please
      By bigdavy in forum Tech Discussion
      Last Post: 18-11-2013, 19:41
    2. Help needed – simple DiY exhaust system; 350 in C-20
      By Barneys66 in forum Tech Discussion
      Last Post: 07-02-2010, 20:23
    3. help please
      By 58 delray in forum Chat
      Last Post: 08-07-2009, 08:03
    4. Help please folks !!
      By andy fadster in forum On Topic
      Last Post: 06-07-2009, 18:17
