Expansion tank fitting
Results 1 to 3 of 3
    Feb 2017
    Cotswolds
    51
    V8107e is offline
    Next question I need answering, my 302 keeps chucking water out the overflow when it gets hot, I've been told to fit an expansion tank to remedy it. On my rad, it's got the take-off under the cap for an overflow and on the opposite side of the rad at the top, there's an inlet/outlet that's been blanked off. So the question is where do I plumb the outlet from the expansion tank to? (If that makes sense!!) Cheers
    Jun 2011
    Keeston, H/west
    1,355
    799
    Perfect65 is offline
    I had a similar thing because I was putting too much coolant in. I fitted an open catch tank on the overflow to monitor the outflow and found no problem if I just about topped the core tubes in the header. If you have a tall rad it's surprising how much the level rises when hot but of course you cannot check it without scolding yourself.
    If you want a sealed system where the overspill is drawn back when the engine cools you need an expansion tank with its own pressure cap and the current filler neck has a non pressure cap that Is just for topping up on first fill. All my own experience but others may offer a different opinion of course.
    Aug 2016
    southampton
    219
    ranchero72 is offline
    stick the drain pipe from the pressure cap in a bottle. it will catch the water that spill out and suck it back in when the engine cool's down.provided you have a pressure cap
    with a return valve
    1. Replies: 1
      Last Post: 20-10-2012, 13:36
    2. Expansion Tank Placement
      By Curnie in forum Tech Discussion
      Last Post: 18-06-2012, 18:00
    3. Replies: 0
      Last Post: 10-10-2011, 15:24
    4. Expansion Tank Water System Plumbing
      By BlueGenePop in forum Tech Discussion
      Last Post: 06-02-2011, 21:18
    5. Replies: 10
      Last Post: 20-09-2009, 17:15
