Fasten the drive shaft to the Jag' IRS?
Results 1 to 8 of 8
    South Norway
    200
    staleg is offline
    Is this how you fasten the drive shaft on to the Jaguar IRS? Simply insert a grade 8 bolt in each hole, nut on the back and then fasten?
    Won't this put enormous amounts of force on those 4 bolts? I have got the rear end of the drive shaft custom made, but admits the conversion of the Jag IRS to a chevy pinion would probably been a better route to go. However now that I have the excisting solution, I want to use it.
    Have I missed someting here?
    Good judgement comes from experience, and a lot of that comes from bad judgement.
    Leicester
    5,691
    592
    bigyellataxi is offline
    Same as Ford did it on MANY cars...
    Fueled by Jim and Luckies.
    Jun 2009
    Rayleigh Essex
    3,104
    278
    trevd is offline
    the forces are not only transmited through the bolts, the mating faces clamped by the bolts take a lot of the torsional force so as long as its done up tight and no corrosion exists between the mating faces its not a problem. you could probably put 3000hp through this type of joint with no problem. just think about a torque convertor, its only held on with 4 3/8 bolts.
    South Norway
    200
    staleg is offline
    Ok. Thanks. Good to know I'm not on the wrong track!
    Do you know where I can get those bolts? I tried locally here in Norway, but the price was 30£ for 4 bolts and nuts...
    Is it ordinary 3/8" grade 8 bolts they use? I can get 12.9 M10 millimeter bolts locally for free at my work and am thinking about drilling out the holes from 3/8 to 10 mm (app 0,5 mm) and use those. 12,9mm bolts are app the same as grade 8 unf bolts.
    Leicester
    5,691
    592
    I would say drill it, but someone else will say not to...
    Pass the lump hammer Blown 100e's Avatar
    Earl Shilton
    550
    30
    Blown 100e is offline
    I would be happy to open up the holes to take a 10mm bolt as its only 0.5mm, 0.020" providing there's plenty of material left on the flange
    Jun 2009
    Rayleigh Essex
    3,104
    278
    trevd is offline
    the bolts, either 3/8 or metric will work but you need to ensure that the part of the bolt in both holes is unthreaded. also a unf bolt will give more force than a standard metric bolt as the pitch of the thread is smaller. if you want to use the correct bolts let me know i can source them and ship them to you at cost (probably more to ship than the bolts will cost me).
    Jun 2009
    Rayleigh Essex
    3,104
    278
    trevd is offline
    picked up the bolts today, will get them in the post asap.if anyone else needs imperial fasteners look at any local bolt/ fastener supplier, i have one near me that can sort me out 95% of the time.
    1. Jag' rear bump stop?
      By staleg in forum Tech Discussion
      Last Post: 15-09-2009, 19:08
    2. Jag' hub question
      Last Post: 23-08-2009, 21:07
    3. Oil leaking Jag' rear...
      Last Post: 21-08-2009, 13:47
    4. 600cc shaft drive bike lump
      By trevd in forum Stuff - FOR SALE
      Last Post: 05-07-2009, 16:27
    5. Drive shaft shortening
      By 30psi in forum Tech Discussion
      Last Post: 25-05-2009, 23:36
