Fiat Twin Cam issues
Results 1 to 10 of 11
    I'm a newbie !
    Jun 2017
    Herne Bay
    10
    Rockabilly Boy is offline
    Been a while since I've posted, but new motor now so new problems!. Basically running a rod with an early Lancia Beta TwinCam motor (same as the Fiat twin Cam) - first thing I've found is any info on the engine is hard to define as there are so many variables. However this one is running Bosch electronic ignition and twin 45's.
    Few days back coming home motor died, no warning, pulled over, keyed the ignition fired instantly and off we went, about 3 minutes later same thing just as we drove onto our drive. Then wouldn't start at all, left it for a few days, cleaned plugs up, checked leads, dissy cap and rotor, all almost new. Stuck them back on, fired first time, ticked over revved, 10 minutes in dies. Won't start - 3 - 4 hours later starts runs 10 min then dies. Def electrical as no spluttering etc just like hitting a kill switch. Any ideas? (Also checked earths and connections so far) Beginnng to wonder if the ECU is playing up, if so 2nd part of the question, anyone set up one of these twin cams with a megajolt unit?
    Just looking at options as sunny days will be here soon!
    Cheers all
    Official RnS Addict ChopperHarris's Avatar
    Oct 2011
    SW France
    1,274
    21
    ChopperHarris is online now
    sounds like a fuel issue to me, at least check float bowls for fuel after it dies
    Jul 2009
    three holes, wisbech, cambs
    5,077
    963
    352 kum is online now
    coil getting hot?
    23,272
    I'd look at fuel first as well .If it isn't used regularly you can get ethanol gum deposits on needle valves that cause all sorts or issues.
    Feb 2010
    Selby north yorks
    1,949
    130
    rodster is online now
    Does it have a distributor ignition control module fitted to it, little black box normally on distributor, i'd be looking at that by what you say.
    I'm a newbie !
    Jun 2017
    Herne Bay
    10
    Thanks for the responses - car has been used regularly and carbs are clean, (aware of ethanol gumming as always an issue with our bikes) Fuel is fine there's fuel sloshing about there when it dies. Convinced it's electrical as fuelling tends to have a final gasp before it packs up! Haven't checked coil heat but I was going to try and borrow a good one to test, and also run an earth wire from the coil strap to ensure that the body is well earthed.I'll have a look for an ignition control module , don't remember seeing anything on the distributor but it may have been relocated. I have been told that the pick up is internal to the distributour so need to figure that out. That's why I'm thinking of going down the megajolt route as easier to get parts and probably easier to set up - will probably mod to bike carbs as well as so much easier to sort than the 45's
    Oct 2009
    grays essex
    381
    16
    sebspeed is online now
    another option could be to fit a points dizzy.
    I'm a newbie !
    Jun 2017
    Herne Bay
    10
    I had wondered about that! Points would be a much simpler option, biggest problem appears to be that no one can tell me which dissy is likely to fit and anything lancia/fiat seems to be a bit vague!
    southampton
    105
    2
    tuckers is offline
    Quote Originally Posted by Rockabilly Boy View Post
    this might be a daft question but when it dies have you checked to see if it still has a spark ?
    I'm a newbie !
    Jun 2017
    Herne Bay
    10
    Yep, no spark leave a few hours and spark back! Ordered new coil and leads in case coil is breaking down. Also found somewhere who supplies replacement pick ups as well as rebuilding dissies. But having run megajolt for years on our Morris think that although more expensive then either megajolt or nodiz will be the way to go. Just need some pennies, so trying to get running on a minimum spend before going down this route
