fibre glass prep
Results 1 to 10 of 12
    gloucestershire
    773
    64
    neil harris is offline
    fibre glass prep
    whats the best way to prep cracked fibre glass .ive removed loose gel coat,is it fill up all pin holes then prime ,or fill up to as good as ,then prime then stopper up little holes .. or is it to open the nozzle and bury the lot with unthinned 2 pack until u cant recognize what it is youve just painted,, hehe ..
    sheffield
    4,207
    1071
    bigjob is offline
    Neil,the only wat to remedy "cracked" fibreglass is to grind out,down to waiver thin,at the actual crack in a graduated "VEE"aprox 3to4 inches either side of it,you may need to "brace the work piece with a simple pop riveted piece of ally or simular depending on the size of the crack,as a temporary support,you should pre cut several strips off glass matting,get an old dish or hubcap,mix your resin with a drop only of catylist,immerse your strips into the resin and stipple in thoughly with a paint brush,when totally absorbed ,transfer the strips one at a time to the workpiece,(its at this point you will realise you need rubber gloves)and stipple in each individual piece,using the mixed resin,leave to thoughly cure,lightly sand ,you need to inspect it carefully at this stage weather it requires more glass/resin, or straight on to filler in the normal way prior to primer,This may read as clear as mud,so if you need to call me on 07802962991,bry
    My Intro
    Insurance Repairs, MOT Work
    or Full On Restorations
    Roberts Motor Bodies
    Home of Henry Hirise
    Click to visit our website.
    View the Henry Hirise Re-Build
    gloucestershire
    773
    64
    re fibre glass prep
    hey thanks boss , is it neccesary to fill up pin holes etc then prime with 2k as this does have substantial filling properties as your most probably aware of..as this mould is pretty pitted etc. its not gunna be a showjob ,just a clean tidy attempt
    sheffield
    4,207
    1071
    bigjob is offline
    Yea Neil ,use a polyester (fine) filler prior to priming,for pinholes,and i really would recommend,you take a couple of hours extra at tis point,even if it means putting "another"spread of filler in,the effort is worth it in the long term,once the paints on thats it dude ,Bry
    My Intro
    489
    langy is offline
    Neil 2 pack primer won't fill the pinholes properley as it will sink back, Get yourself some 2 pack stopper which 9is like creamy body filler.
    gloucestershire
    773
    64
    re fibre glass prep
    hey ,thks people ,langy cheers for that i will aquire some of the 2k stopper as it is definately in need of some ,cheers bry ,i know you get out what you put in so if it comes up fair then ill be happy .. if filling be the food of life lets eat errr c you in ten years haha
    Notts
    168
    13
    6-71 is offline
    Neil, I've got the same problem, Can you let me know how you get on with that 2 pack stopper, Cheers, Honk
    gloucestershire
    773
    64
    two pack stopper
    yes m8 no probs ,..
    Fruit & Nut Case great68's Avatar
    North London
    2,100
    334
    great68 is offline
    I was told to always drill a about 4mm hole at the end of the crack. This will stop it spreading.
    gloucestershire
    773
    64
    re drilling holes
    hmm interesting thks ,.. dood i like the tesco brand image haha that is class!!
    1. glass rod
      By foster in forum Vehicles - WANTED
      Last Post: 18-12-2009, 20:55
    2. Glass Cut.
      By StueyT in forum Chat
      Last Post: 04-12-2009, 17:01
    3. Pop glass
      By Spock in forum Stuff - FOR SALE
      Last Post: 03-10-2009, 22:54
    4. Mk2 zephyr fibre glass boot lid
      By ZEPHYRV8CHRIS in forum Stuff - FOR SALE
      Last Post: 27-07-2009, 10:15
    5. fibre glass prep?
      By neil harris in forum Tech Discussion
      Last Post: 10-05-2009, 10:45
