fitting pertronix kit 2.
Results 1 to 4 of 4
    Sep 2009
    Norfolk
    326
    15
    Tiddytime is offline
    RIGHT, follow up to fitting pertronix kit, I fitted it in situ,
    a bit of a pain but sorted, left original delco coil on to see
    if engine started ok, and yes it ran fine, but the car has a
    ballast resistor on the firewall which would have been there
    when it had a inline 6 originally from factory, It has had a
    v8 in when it came here from the states years ago, I bought
    a flamethrower coil to fit as well (1.5 ohm) and the paperwork
    states don't use ballast resistor, the coil/ignition wire is coming
    from the starter motor for what I can see, but my multi meter
    is on the blink and can't check coil for voltage,(9 volt) am I
    right in thinking that ballast resistor cuts coil down to 9 volts,
    ballast resistor has wires on that go through firewall behind dash,
    so could original coil have been running at 12 volts or would it
    have burnt out if this was the case, Richard.
    12,628
    yes a ballasted coil is 9 volts, the idea is the coil is fed 12 volts when cranking to get a hotter spark on startup. you will need a full 12 volts for the pertronix coil.
    Sep 2009
    Norfolk
    326
    15
    So bypass the ballast resistor,and fit flamethrougher coil,
    and should be good,
    8,674
    1754
    blackpopracing is offline
    Yep.
