fitting pertronix kit.
Hi There, bought a pertronix ignitor kit and coil for my
55 chevy, the instructions look straight forward enough
but they say take the distributor out of the engine,
its probably the easiest way to fit the kit but I would
be happier fitting it in sitchue, so the timing will still
be right, the air gap between the ignitor and the magnet
ring has to be between .10 to .60 and if I don't have to
shim the shaft above the camdrive could I struggle with
the dizzy in, this is a chevy v8 so a bit of a stretch,
your thoughts, cheers Richard.
It shouldn't be any different to fitting a set of points so I'd leave it in there. Make sure the wires inside the distributor wont foul any moving parts
The timing will almost certainly change even if you do manage to change it over in situ. Best to check it afterwards to be safe.
Cheers, Martin
Maybe I'm just sick in the head.
Post Thanks / Like - 1 Likes
I fitted one to my cars Pontiac 350 9dizzy at the back) I hate timing engines so fitted it in situ, carefully followed the instructions and well impressed
Been good so far
Thanks for that, I will install with dizzy in, if I have any concerns
my mate is a mechanic. cheers Richard.
