Flathead ignition help
Results 1 to 7 of 7
    Jan 2015
    Down south
    42
    rachet is offline
    I need a little help tracing a ongoing problem. I've got a flathead with the diving bell style distributor it starts and runs fine until it gets hot (maybe around 160*) then it wont rev and has no power and dies then wont start until it cools down. Its had new fuel pump, carb, coil , condenser, ballast resistor, plugs, and still it persists any help appreciated!
    Jun 2016
    Roswell, New Mexico
    604
    NMNeil is offline
    Valves too tight and staying open, as the valve stem expands when it gets hot?
    Free and easy to check.
    May 2016
    S E London
    840
    22
    timbo56 is offline
    I had that problem with an old 1936 Rolls I used to drive, it'd cut out on tickover when hot and not restart for a while, very embarrasing when you have a new bride and groom in the back. Turns out the bloke who owned it had run it solely on unleaded and the valve seats had worn down and the clearances were non existent when hot
    up north
    1,989
    35kid is offline
    i would try another condenser, new ones don't have a good reputation.
    Jun 2016
    Roswell, New Mexico
    604
    NMNeil is offline
    Quote Originally Posted by 35kid View Post
    Can't see that making any difference.
    I'm a newbie !
    Sep 2012
    Burlington, Wisconsin, USA
    2
    jmbo is offline
    If you are using a mechanical fuel pump take look at the push rod. They wear and at some point they wear to the point were they will not fully activate the pump. When flatheads get hot the fuel tends to vaporize. This is very common and is due to the manifold sitting directly atop the motor. This results in what is called vapor lock and the engine will not perform properly. To prevent this you need a full functional fuel pump. Good luck.
    Official RnS Addict zefa46's Avatar
    Westhoughton Bolton lancs
    1,414
    174
    zefa46 is offline
    sounds similar to mine , turned out to be the vac advance diaphragm $6 fix , take it off and blow through it . minr ticked over ok but got hot and boiled when run. easy fix and easy test worth a try
    1. Flathead ignition
      By rachet in forum Stuff - WANTED
      Last Post: 30-03-2017, 19:07
    2. Ignition Help
      By sedatev8 in forum Tech Discussion
      Last Post: 12-10-2016, 19:46
    3. Essex V6 ignition help please...
      By bigyellataxi in forum Tech Discussion
      Last Post: 10-03-2015, 22:09
    4. help with ignition timing?
      By scrapyarddoguk in forum Tech Discussion
      Last Post: 27-02-2012, 18:28
    5. 2.0 Pinto electronic ignition :( wiring help
      By lowriderchris in forum Tech Discussion
      Last Post: 23-10-2011, 12:01
