Ford 289 running issues.
Results 1 to 10 of 33
    Nov 2013
    Between Tamworth, Polesworth & Atherstone
    29
    surferjoe is offline
    I have had problems with a 289 for the last 2 yrs. so far changed fuel pump to electric and back to manual. Added electronic ignition. Changed the carb and fuel filter. Changed coils and leads. The problem is that sometimes it's a pig to start. Sounds like it wants to catch but won't. Other times it starts and runs (very well) and then just cuts out and won't restart.
    It doesn't cough and splutter to a stop it's almost like the ignition has been turned off. It tries to catch but won't. It's almost like the spark is to weak?
    If that makes sense? I don't really understand tricity!! I'm more of a bit of a bit it with a hammer man.
    Any ideas?
    Thanks
    Nov 2012
    suffolk
    164
    buick350 is offline
    heat soak/ vapour lock? is it heat related do you think? was it points ignition with resistor wire?
    Nov 2013
    29
    No it's not heat. Once it's cooled down it's still difficult to start. Once started it's ok. It did have points and condenser but I changed it to an accuspark electronic ignition kit.
    Jan 2011
    manchester
    1,305
    markmustang1 is offline
    sounds like the points or condensor,but since you have changed them,cant be that,sounds electrical.make sure the coil wires are tight and insulated.also the connections to the starter solnoid.mark
    YamYam central
    3,489
    453
    74
    sidspop is offline
    Bad earth.
    Renew and double earths. One from battery to chassis. One from Battery to block.
    Eliminate the simple stuff bfore diving in to the complex.
    13,422
    mygasser is online now
    add a new temporary ignition live from the battery (fused of course) to a switch then to the coil. if it's ok with that there's an intermittent break in the coil feed.
    Jan 2012
    norwich
    1,904
    9
    2
    63Wagon is offline
    Would a non resistor wire to coil do this when it should be a resisted wire . Coil could be getting hot and shutting down
    13,422
    normally with electronic dizzy a full 12v is required
    Nov 2013
    29
    Coil isn't getting hot and I have tried 2 coils and it made no difference. I think the earths are ok but easy to double them up and renew them so will try that. I don't understand the resistor wire ???
    I should be getting 12v from the coil?
    Official RnS Addict GT350's Avatar
    Jun 2009
    SUNNY GLASGOW
    3,164
    126
    GT350 is offline
    is this in a mustang?
    1. Ford 289 running issues.
      By surferjoe in forum Tech Discussion
      Last Post: 30-12-2013, 17:17
    2. small block ford 289 302 (sleepy)
      By watwat in forum Stuff - WANTED
      Last Post: 05-03-2011, 08:21
    3. ford 289/302 weiand single plane intake used
      By GT350 in forum Stuff - FOR SALE
      Last Post: 13-01-2011, 17:33
    4. ford 289 pulleys
      By mustang289 in forum Stuff - WANTED
      Last Post: 05-04-2010, 16:16
    5. Ford 289 Block
      By havoc in forum Stuff - WANTED
      Last Post: 01-03-2010, 09:50
