Ford 351 Windsor piston direction
Results 1 to 10 of 10
    Jul 2011
    sidmouth devon
    2,488
    370
    dave 62 pb is offline
    I have just pulled the heads of the 351 Windsor engine that I have acquired and noticed not all the directional notches face the same way
    6 face forward and the rear facing are rear offside and 3rd on nearside , should the notches face forward or to the rear
    Cant find a straight answer on the net ,but every other engine I have built the notches or arrows face the front
    The engine has been running this way without any damage
    12,926
    they normally face forward as you say, something to do with the gudgeon pin being slightly off centre so there is a thrust side to the piston. maybe the piston was fitted to the rod the wrong way round. if you're rebuilding it it won't matter, if not it was running ok so it won't matter
    is this the boat engine? swap the cam out, they only rev to about 4000 rpm with the boat cam usually.
    Jul 2011
    sidmouth devon
    2,488
    370
    Hi , yes its the boat engine , i have since found out that some are built to rotate the other way and its not uncommon to have pistons facing in different directions
    I will be rebuilding anyway so will be fitting mild car cam and distributor , on the upside the bores are good with + 30 pistons , crank is good with std big ends and -020 mains , inside is very clean , it looks like its not done many hours since rebuild
    The water jacket has a bit of loose scale and when touched just falls of , from what i can see there is no corrosion or pitting to the cylinder walls , the only problem i have is the distributor was bent and seized solid into the block , i cut the shaft part way down and drilled small holes around the distributor base next to the block and left soaking in penetrating oil
    I think i will have to make a puller and use a little heat to get it out
    Jul 2011
    sidmouth devon
    2,488
    370
    BTW, advise welcome on the choice of cam , its just going to be normal road use and towing my caravan to shows , seen some from Summit and ebay USA for reasonable money
    12,926
    Edelbrock performer cam kit often is cheaper than cam an lifters bought separately if you want name brand. Summit own brand though are just fine from what I've seen, they do a performer equivalent too.
    Neil
    Jul 2011
    sidmouth devon
    2,488
    370
    seen Enginetech cam and follower kit £131.00 delivered with duty paid or the Summit kit is quite cheap but not sure on postage costs, there is also Comp cams which look ok with decent reviews
    will look at Edelbrock performer also
    Thanks
    12,926
    the performer is quoted as idle to 5500 rpm, i've fitted probably 3 or 4 now in different makes of engine. all showed good low to mid range and would run to 6000 cleanly too. sounds ideal for what you intend, recommended so if you can get a same spec cam cheaper go for it.
    Jul 2011
    sidmouth devon
    2,488
    370
    This engine is bugging me why it wont turn a full revolution , I have now got it stripped to just the block /crank and pistons
    As I said before it looks to me like some of the pistons are the wrong way round and although there are no marks on the underside of the pistons they are too close for comfort to the crank for my liking when on the bottom stroke , I cant quite see but they could be bottoming out + they just don't look right
    I got the broken distributor out as I thought it might be that stopping the engine turning over, I suppose the next step will be to remove the rods and pistons that I think are wrong and see what happens
    Jul 2011
    sidmouth devon
    2,488
    370
    Found the problem with the engine not turning fully , slight bend in no 3 con-rod sods law it was the last one to come out , but also found this bodge on no 1 piston
    Jul 2011
    sidmouth devon
    2,488
    370
    Since found all the pistons were on the correct way to the rods , but the previous builder did not understand Ford cylinder numbering and put them in wrong order
    1. Ford 351 windsor v8 engine
      By Automan in forum Stuff - FOR SALE
      Last Post: 08-04-2013, 13:36
    2. Ford 302 or 351 windsor
      By voodoom in forum Stuff - WANTED
      Last Post: 19-08-2011, 19:05
    3. Ford 351 windsor v8
      By lead foot in forum Stuff - FOR SALE
      Last Post: 26-06-2011, 11:49
    4. Ford 351 windsor
      Last Post: 16-06-2011, 09:57
    5. HEI Dizzy for ford 351 Windsor
      By Marc in forum Stuff - WANTED
      Last Post: 26-01-2011, 12:27
