Ford 351w misfire
Results 1 to 10 of 11
    Rods 'n' Sods Junkie Chucky's Avatar
    May 2010
    Ipswich
    151
    19
    Chucky is offline
    Ford 351w misfire
    I have got a misfire on my 351w motor, I have spark all round but it appears as though fuel is not getting through to cylinder number 4. I have a good spark and the engine starts fine but runs on 7 whether it is idling or when I rev it up.
    I remove the plug on number 4 and it is dry and clean whilst the other plugs are a little sooty.
    I have changed the leads, plugs, rotar, cap, carb and coil and no difference!
    I have also done a compression test which was good and vacuum test which was good.
    Anyone got any other ideas as it's driving me crazy! Cheers Tony
    Mar 2015
    Lowestoft
    57
    2
    Woodsyv12 is offline
    Stab in the dark.....Is the inlet or exhaust lifter holding the valve open when it's running. This may not show up on a compression check as oil pressure maybe lower????
    If it was exhaust the plug may stay dry??
    May 2010
    Ipswich
    151
    19
    Chucky is offline
    I have run the engine with the rocker cover off and it all seems ok, everything appears to be moving correctly.
    Mar 2015
    Lowestoft
    57
    2
    Valve lash set ok? or is it non adjustable type?
    Sep 2011
    Kings Lynn
    3,202
    464
    brading is online now
    Two things I would try is to check it in the dark ( the darker the better ) to make sure the lead is not shorting out, I would also check it with one of these.
    https://www.amazon.co.uk/Silverline-...rk+plug+tester
    May 2010
    Ipswich
    151
    19
    Chucky is offline
    Quote Originally Posted by Woodsyv12 View Post
    It was set right but I suppose there's no harm in checking it again.
    May 2010
    Ipswich
    151
    19
    Chucky is offline
    Quote Originally Posted by brading View Post
    I have tried a few different leads and several plugs, the spark is good when checked with the plug out of the engine and I have a similar tester to the one you linked me too and that shows it sparking!
    This is the sole reason I am really baffled.
    It was running fine and was 130 miles into a 140 mile round trip when it suddenly developed the misfire . Cheers
    Jun 2016
    Roswell, New Mexico
    878
    NMNeil is offline
    A GENTLE spray of carb cleaner around the intake manifold where it connects to the #4 cylinder part of the head. Easy check for a vacuum leak which may not always show on a vacuum test.
    May 2010
    Ipswich
    151
    19
    Chucky is offline
    I'll give it a try next time I'm over the the workshop .
    I did fit a new intake and gasket plus new head gaskets last year so the gaskets should be good but worth a try
    Mar 2015
    Lowestoft
    57
    2
    Did you fix this issue?
    1. Ford 351W motor and C6 Box
      By billyboy132 in forum Stuff - FOR SALE
      Last Post: 07-11-2010, 11:03
    2. Ford 351W engine and TH400 Tranny
      By lead foot in forum Stuff - FOR SALE
      Last Post: 25-08-2010, 08:36
    3. Ford 351W and bits
      Last Post: 21-03-2010, 23:05
    4. Ford 351W Gasket Set
      By Zody in forum Stuff - FOR SALE
      Last Post: 20-03-2010, 09:39
    5. Beautiful 370 HP Dyno Tested Ford 351W for sale (video link)
      By Flemming in forum Stuff - FOR SALE
      Last Post: 29-01-2010, 22:06
