Ford 5 speed gearbox question
Results 1 to 10 of 11
    Sep 2009
    54
    koolhandluke is offline
    Hi lads, my mate asked me a question that I couldnt answer so I thought I'd put it on here.
    Is there any diference between a 5 speed Scimitar,Ford gearbox as fitted to 3 litre essex engines and the Cortina,Sierra 5 speed box?
    Hope someone can answer this as he really needs to know before he buys a new unit.
    cheers lads
    Jun 2009
    Birmingham, UK
    863
    ThomasHarris is offline
    Id like to know the answer to this aswell
    When the flag drops, the bullshit stops.
    Official RnS Addict harris66's Avatar
    Jul 2009
    solihull
    2,385
    79
    harris66 is offline
    the scimitar was a 4 speed with overdrive i beleive, the cortina a 4 speed and the seirra a type 9 5 speed, i think
    i want cubic inches! lots of em!!
    Nr. Dartford, Kent
    2,725
    244
    stueeee is offline
    Haven't seen a 5 speed in a Scimitar but there are at least two different types of Type Nine gearbox. The ones that were original equipment on the V6 engines (Capri, Granada etc.) had a longer input shaft and deeper bellhousing than the ones used on the four cylinder motors.
    HTH
    Stuart.
    My Intro
    23,198
    Coarser splines as well between Scimitar box and 'standard' small Ford.
    EDIT : He's not talking about a Scimitar Sabre is he ? That was a revamped Reliant SS1 with a 5 speed.
    Rods 'n' Sods Junkie GVTdrums's Avatar
    East Sussex
    142
    GVTdrums is offline
    Yes. The input shaft on the sierra type 9 is shorter whereas the type nine for the essex and colonge engines have a longer input shaft and different splines. I believe the gears are transferable between the two types. However the type 9 for the colonge/essex will not fit a zetec engine (got the t-shirt).
    Zetec powered pop on its way!
    My Intro
    My Project
    Sep 2009
    54
    Without having both types of type 9 gearboxes to hand,is there anther way of telling the gearboxs apart ie serial numbers, or other identification marks.
    Quote Originally Posted by GVTdrums View Post
    East Sussex
    142
    GVTdrums is offline
    The bellhousing is the obvious difference. The essex/colonge box has the bolt holes to mount it to the engine close together whereas the sierra type has them further apart. If your still struggling I've got one of each at home. I'll measure the shaft and make a note of the spline on both gearboxes and get back to you. I'll also take a picture of the different hosings. Hope this helps.
    My Intro
    My Project
    Sep 2009
    54
    Cheers mate, this will be invaluable as hes fittin a 2 ltr pinto and has a type 9 box and really needs to know its origins.
    I look forward to your next posting fella
    Jun 2009
    1,802
    v8ian is offline
    There were no 5 speeds available for the V6 Essex other than the odd ZF conversions made for Superspeed. I doubt if you will find one of those,
    There is one factory bellhousing made by ford that will convert the v6 colonge gearbox [type9] and this is also a rare thing, made for about 6 months, fitted to v6 Mk1 granadas, and these fetch a premium too, I saw one go for £400 on evilbay recently, as you can guess they are hard to find too,
    All is not lost, the Capri v6 5 speed can be converted to fit a essex bellhousing, Capri and Granada are cable and Mk4 zephyr, scimitar and Corsair are hydraulic, I did one recently for a mate, You need to machine a spogot ring to locate the gearbox, its about 1mm thick, I made a tophat and screwed it to the inside of the bellhousing, this now allows the type 9 to fit snugly and concentric to the bellhousing, you now need to make a template for the bolt holes of the gearbox, once thats made spot the holes thru, and then you can spot face the inside of the bellhousing so the bolts seat correctly, there is another hole at the top of the bellhousing that needs to be made to accomodate the 5th gear selector rod that exits the gearbox, this will protude out into the clutch area, and will need an oil tight cover made for it, you also MUST have a gasket or sealant between the bellhousing and grarbox. Clutch I never did, but its IIrc the essex clutch arm and bearing, Cologne friction plate, and essex pressure plate, probably have tomake a new bronze spigot bearing too,
    1. Ford 3 litre 4 speed gearbox
      By Adey in forum Stuff - FOR SALE
      Last Post: 31-05-2010, 21:24
    2. Ford C4 gearbox question
      Last Post: 28-04-2010, 21:56
    3. I am looking for a 5 speed rover SDi gearbox if any one can help
      By gasser consul shane in forum Stuff - WANTED
      Last Post: 21-04-2010, 11:24
    4. NO LONGER REQUIRED 3 speed gearbox,
      By satan in forum Completed or Expired
      Last Post: 08-03-2010, 21:02
    5. Ford Sierra 4 speed auto Gearbox
      By Mr 440 in forum Stuff - FOR SALE
      Last Post: 01-01-2010, 15:12
