Ford 9 inch half shaft question (splines-power)
Results 1 to 10 of 11
    Sep 2014
    The north
    1,363
    1314
    nuggets is offline
    Ok people quick tech question.......in your expert opinions or user tested experiences. For a street vehicle which will be running street tyres (285/60/17) and never on slicks. 500bhp at the flywheel (eventually) and a 4.11/4.55 rear end with a toploader would you say that 31s are overkill or would they be a necessary upgrade over the original 28s.....assuming once the original 28's break (if they do) I'd upgrade to Moser or Strange hardened ones
    I'm assuming my drive shafts are 28's rather than 31's due to the fact its not a locker and I'm not using a truck even if it has these dimples in the end of the shaft rather than the single large cut out.....apparently the two small dimples only works for pre 71 stuff
    This is a Ford 9" obviously and the vehicle comes in at about 1900kg
    12,757
    moser or strange 28 spline shafts will be much better than stock but with 500 hp i'd be tempted to go straight with 31 spline when the stock ones break. remember to budget for a 31 spline diff too.
    Sep 2014
    The north
    1,363
    1314
    nuggets is offline
    Well I've got a quote from Andy Robinson for a complete 31 spline set up so I know how much it'll cost me
    I really need to pull one of these shafts fully and see what I have as if it turns out I have 31's already it'll make life a lot easier/cheaper!
    Herts
    4,588
    198
    WB54 is offline
    Quote Originally Posted by nuggets View Post
    then get a quote from Summit delivered to your door, significantly cheaper than buying through a UK company
    Sep 2011
    Fareham
    1,227
    normalbloke is offline
    Or Jegs. Their postage on some items is comedy cheap!
    kent
    2,892
    choppedblownpop is offline
    Quote Originally Posted by normalbloke View Post
    Do Jegs do the I parcel like Summit ?
    Sep 2011
    Fareham
    1,227
    Quote Originally Posted by choppedblownpop View Post
    I've only bought stuff from Jegs via their ebay shop so far, which uses the global shipping program. Ie, when you check out, it includes all duty and fees. No more £8 rip off Parcelfarce fees. As an example I bought a box of 12 quarts of Joe Gibbs break in oil, and the postage was something like £17.
    Official RnS Addict rootesix66's Avatar
    north kent
    1,112
    191
    rootesix66 is offline
    ive got 28 spline moser shafts in mine...its got a detroit locker & 10" wide tyres....so far i have managed to snap a pair of profesionaly shortend std 9" shafts,kill a hughes torque convertor & a real steel built 302....but the moser shafts have held up so far
    crazed country rebel
    Official RnS Addict popleea's Avatar
    hillingdon
    567
    267
    popleea is offline
    28 spline shaft should be fine for street use on street tyres..had mine on the pop for years with no probs, it's when you put on drag radials and hit the track doing this
    This will happen
    Then it's time to get Wayne at Oddrods to build one of these with 31 splines...
    That was my first ever car that was........
    Sep 2014
    The north
    1,363
    1314
    nuggets is offline
    It would be but AR are £1280 in the UK with taxes paid for the complete third member built to my spec and then a set of Strange shafts with studs, bearings plates etc are £600 + VAT, total cost £1980 inc VAT
    Summit will only ship to an airport on the 3rd member!
    1. Ford 9 inch half shaft question
      By nuggets in forum Tech Discussion
      Last Post: 08-01-2015, 19:52
    2. ford/mercury half shaft
      By vinny in forum Stuff - WANTED
      Last Post: 28-01-2014, 20:57
    3. Half shaft splines
      By Bumper in forum Tech Discussion
      Last Post: 17-06-2012, 19:43
    4. Ford Half Shaft Lengths.
      By BillyBones in forum Tech Discussion
      Last Post: 23-07-2011, 13:28
    5. Ford Capri Mk1 3ltr Half Shaft Urgently Wanted
      By Gr8h8me in forum Stuff - WANTED
      Last Post: 27-09-2010, 14:11
