Ford c4 help
Results 1 to 7 of 7
Thread: Ford c4 help
    Feb 2017
    Cotswolds
    51
    V8107e is offline
    Ford c4 help
    I haven't run my car since last September until today, when I parked it up all was working well. All I've changed is the carb over the winter. When I took it for a drive today, in Drive it was changing up fine, but when it got below 25mph it changed down gear rather quickly, to the point where it was really jerky, and it never did before it was parked up, it changed down smoothly. Any ideas why it would be doing it now? It's a c4 behind a 302.
    Feb 2013
    uranus
    2,038
    ivanhoew is offline
    is there a vacuum take off from the carb to the gearbox ?
    if so, is it on the right stub on the carb ,there may be a constant vacuum source stub, and a ported stub, that only works once the throttle is open a set amount , i think you want to be on the constant source .
    regards
    robert.
    Bicester scramble ,Medusa enjoyed the trip.https://www.youtube.com/watch?v=Q-7I7-nA19U
    12,522
    mygasser is online now
    what carb did it have and what is fitted now?
    Hornchurch, Essex
    2,461
    9
    30psi is offline
    Good advice above. Only thing to add is if there's a lack of vacuum i.e. you forgot to reconnect the hose at all. Or the kick down linkage from the carb is hanging loose...
    '62 Ford Thunderbird
    '81 Datsun Bluebird SSS Turbo
    Feb 2017
    Cotswolds
    51
    V8107e is offline
    Previous carb was an edelbrock that I borrowed to see if it was any good for my set up, I've now bought my own edelbrock. Vacuum lines connected to the drivers side port on the carb (it's right hand drive) same as the other carb.
    Official RnS Addict rootesix66's Avatar
    north kent
    1,112
    191
    rootesix66 is offline
    check the other end of the pipe where it goes into the modulator on the gearbox..if all seems ok make sure no splits/holes in pipe,if thats all good,take the pipe off at the gearbox end & look inside the modulator ..it maybe adjustable with a slotted screwdriver (ive had these work loose before)
    just offering some free advise based on what ive experienced myself..i dont pretend to understand the full witchcraft of a slushbox!
    crazed country rebel
    May 2013
    Newton aycliffe
    72
    Bokker is offline
    I have same 302 and c4 Dont forget the big port at the rear , is it blanked off ?
    1. 9" Ford halfshaft help please.
      By blackpopracing in forum On Topic
      Last Post: 01-12-2012, 19:31
    2. 8" ford AXLE HELP
      By escortrs2000 in forum Stuff - WANTED
      Last Post: 15-08-2012, 14:43
    3. ford 8" help/info
      By shorty's shaker in forum Tech Discussion
      Last Post: 15-07-2012, 18:38
    4. ford cologne help.
      By issigone in forum Tech Discussion
      Last Post: 27-05-2012, 07:53
    5. 34 Ford expert help please
      By TCRacing in forum On Topic
      Last Post: 13-01-2012, 13:27
