Ford diesel wont rev!!!!
Results 1 to 10 of 11
    Sep 2009
    norfolk
    283
    7
    wheelie is offline
    Hey All,
    I finally got the air out of my Ford 1.8 XLD and it has now started, but it runs at high revs and when you press the throttle nothing at all happens, it just keeps revving. Any ideas why?
    I drove the Fiesta that it was in, to my garage, took it out and fitted it elsewhere without touching any adjusting screws or the like, only change being fitting an electric fuel pump at the tank, could that be the cause?
    Thanks, Ady
    TechnicalTom
    Nov 2009
    CORK IRELAND
    391
    9
    TECHNICALTOM is offline
    ya
    Jun 2009
    bromley, kent
    1,391
    390
    prostreet70gto is offline
    had THE EXACT same prob on a citroen AX diesel, the prob was the lift pump and fuel govenor at the front of the engine.
    Col
    Heavy Oiler Col's Avatar
    Feb 2010
    berks
    2,502
    299
    Col is offline
    Is the throttle cable too tight?
    There are 2 stop screws, 1 either end of the throttle lever travel on the pump. Make sure lever is against the idle stop with no throttle, and against the throttle limit screw at full throttle>
    https://www.rodsnsods.co.uk/forum/signaturepics/sigpic2162_1.gif Now off the road for body off rebuild. Will have blown bigblock & 5 spd gearbox.
    Jul 2010
    Hampshire
    413
    52
    truckdoctor is offline
    Make sure the electric pump is not sucking air in and that all the is air removed from the system especially the delivery pump. Good luck
    Sep 2009
    norfolk
    283
    7
    wheelie is offline
    Grrrrrrrr grrrrrrrr grrrrrrrrr grrrrrrrrrrr. I been trying to sort this out for 2 solid days now all to no avail. It's a simple set up, fuel tank, pipe to electric pump, pipe to filter, pipe to Inlet on injection pump, all new parts up to the injection pump. Return pipe to tank has no valves, it just goes straight to the tank.
    I've tried bypassing the electric pump, the revs died down but the throttle still didn't work.
    I've removed the return pipe, no difference.
    The throttle cable is not connected.
    Disconnected the waxstat cable, no difference.
    I'm pretty sure that no air is getting in anywhere.
    I've taken the top off the injector pump and it all seems to be working fine and the shaft is turning with the lever.
    I really don't want to have to pay for a reconditioned injection pump unless it is absolutely 100% the cause of the problem.
    Tried 5 local garages this morning to see if a mechanic can come out to me but none will even entertain leaving their tearoom behind, and unfortunately I cannot get it to them.
    The engine had stood for 4 years, could something be gummed up somewhere do you think. I assume that the governor is one of the moving parts at the top of the injection pump. Bosch diesel pump schematics seem to be a bit sparse.
    Time for some beer I think.
    TechnicalTom
    Nov 2009
    CORK IRELAND
    391
    9
    ya
    12,567
    mygasser is online now
    crimp the return line with molegrips and see if it improves. some had a resrictor in the return
    Jul 2010
    Hampshire
    413
    52
    Possible the delivery pump is stuck internally if it's been sitting around. Have had this problem with CAV pumps, don't know what to suggest to help you other than try a replacement, this is the part that controls the fueling and if it's delivering a fixed amount this will give give you the symtoms you describe. Good luck.
    Sep 2009
    norfolk
    283
    7
    wheelie is offline
    Hey Everyone, thanks for the ideas, had to remove the pump and take it to a specialist in the end. Truckdoctor was nearest the problem. Apparently there was water inside and as it sat so long, something rusted to something else and another bit got stuck somewhere.
    Lesson learnt, don't leave a diesel engine sitting unused for a long while.
    1. rover v8 wont rev , help !
      By smurf in forum Tech Discussion
      Last Post: 03-07-2011, 18:52
    2. Ford rev counter
      By Gasolinescream in forum Stuff - FOR SALE
      Last Post: 23-02-2011, 17:04
    3. Ford escort diesel estate
      By MOPARCRAIG in forum Vehicles - FOR SALE
      Last Post: 22-02-2011, 18:13
    4. American brochures + V8 Ford Chevy Diesel workshop manual
      By hurnleft in forum Stuff - FOR SALE
      Last Post: 22-11-2010, 11:27
    5. WHEELS..10 x 15s.. US.Ford...and Rev Counter....
      By BRIT DIGGER in forum Stuff - WANTED
      Last Post: 18-01-2010, 09:40
