Are ford diesels notoriously hard to bleed???
Results 1 to 9 of 9
    Sep 2009
    norfolk
    283
    7
    wheelie is offline
    Hey All,
    I'm angry. I spent almost all of yesterday trying to get a 1997 1.8 Ford XLD started with no luck. Just for info, it has an electric fuel pump before the filter. The fuel solenoid is new and can be heard clicking. Small air bubbles and fuel keep coming out of the injectors when I slacken them, but the bugger won't start.
    I've bled the filter and it has plenty of fuel in.
    Do I just have to keep cranking it over or is there an easier way to get air out of the system (which I assume the problem is). It is meant to be self bleeding so doesn't have any primers anywhere.
    Thanks, Ady
    Lee
    Fat 'n' Loud Lee's Avatar
    Derby
    4,766
    493
    Lee is offline
    Yes, they're bleedin' hard.
    Sep 2009
    norfolk
    283
    7
    wheelie is offline
    You velly funny man
    Nov 2009
    stourport
    5,524
    7
    beach57 is offline
    Check all pipe concetions as it could be sucking air in
    Col
    Heavy Oiler Col's Avatar
    Feb 2010
    berks
    2,502
    299
    Col is offline
    I've had no probs bleeding them. Sure it's not glow plugs? Or cam belt / timing?
    https://www.rodsnsods.co.uk/forum/signaturepics/sigpic2162_1.gif Now off the road for body off rebuild. Will have blown bigblock & 5 spd gearbox.
    Erect member
    Feb 2011
    Yer maw's
    254
    Diggedydawg is offline
    Make sure the fuel filter is full, if possible, bleed the system up to there, then work the glow plugs as normal, and have someone turn it over while you squirt WD40 into the intake.
    See if it starts. If it catches, stop spraying WD40 straight away, and see if it'll keep running
    Could be an airlock somewhere, if you can get it running, it'll turn faster than on the key.
    Don't listen to anyone who tells you that engines become dependent on it.
    They don't.
    If it needs help to start, it's because it needs maintenance, not because it needs spray.
    Most Fords are self-bleeders, and they can take absolutely ages, sometimes a little spray, or a tow is the only way to do it.
    You may find that having the injectors open is wrong, and the system should be closed.
    When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the others in the car.
    Official RnS Addict Special When Lit's Avatar
    Derby
    1,270
    593
    Special When Lit is offline
    Tow it down the street in 2nd gear, always works for problem diesels.
    If you can't be an example, be a warning.
    Official RnS Addict 1968unclefester's Avatar
    faversham kent
    688
    454
    1968unclefester is offline
    crank it over with the injector pipes cracked off to see if diesel is getting through , when you try starting does it puff smoke from exhaust
    on my diesel fiesta 1.8d it was a bugger to start so we fitted a facet electric pump before the filter to act as a primer and it then started like a new car and is still fitted 2yrs later
    Sep 2009
    norfolk
    283
    7
    wheelie is offline
    Thanks for all your replies Lads, I found a loose joint eventually so it was sucking air in whilst I was trying to bleed it. I'm much happier today now.
    Ady
    1. what are best seats to fit Ford Pop
      By crokandok in forum Chat
      Last Post: 26-07-2010, 14:01
    2. Times are hard
      By fozwanger in forum Stuff - FOR SALE
      Last Post: 08-03-2010, 18:46
    3. How hard are ........
      By vince-305 in forum Who are ya ??
      Last Post: 23-01-2010, 08:42
    4. ford pop handbrake
      Last Post: 22-04-2009, 19:00
