Ford Zephyr mk3 engine swap wheels
Results 1 to 10 of 18
    Official RnS Addict fordf350camper's Avatar
    Jul 2009
    nottinghamshire
    725
    fordf350camper is offline
    My brother has a 1964 Ford Zephyr what engine would fit with out cutting chopping it up.Would a 302 fit and a auto box,What wheels would fit any idea on the wheel pcd.Thanks
    fat rotbox rodder hurtz's Avatar
    beyond the sun waltham abbey
    5,758
    916
    hurtz is offline
    a friend of mine had a MKIII zodiac with a 302 in 20 years ago I don`t think the bulkhead was cut .I recall it had stock front suspension but with narrowed 8 inch rear mustang axle.it had 14 inch steel mustang wheels all round
    livin' on beer 'n' jaffa cakes -one box per pint
    12,896
    mygasser is online now
    302/c4 fits easy. even the umbrella handbrake can still work, just re angle the cable roller bracket towards the o/s to clear the rocker cover. 351w and 351c similar story with the additional job of adding a flat to the side of the fan housing to clear the n?s rocker cover. i even had one with a tall deck 400m although the servo had to be replaced with a remote item due to the width along with an internal heater fan. mounting the gearbox from memory i turned the chassis mounts upside down to lower the crossmember a little bit for tunnel clearance.
    regards, neil.
    ps here's one with a 351w i prepared earlier, note the heater fan housing with the 'flat' part.
    Jul 2009
    nottinghamshire
    725
    Thanks for the help.That engine looks good in that engine bay.What is the wheel pcd thanks
    Official RnS Addict zefa46's Avatar
    Westhoughton Bolton lancs
    1,431
    163
    zefa46 is offline
    5x4.5 same as mustang american ford , Volvo amazon I had 6x15 front and 8x15 rear , the standard axle will be ok with a stock motor but for 8x15 will need narrowing 3"
    ran a 3lt V6
    12,896
    ford/mopar 5 x 4.5" pcd or 114.3mm in metric. i've got a set of weld rodlites that ought to fit for sale https://www.rodsnsods.co.uk/forum/st...ls-sale-545689
    1,431
    163
    zefa46 is offline
    Flange Dealer Paul G's Avatar
    Derby , UK
    642
    57
    Paul G is offline
    Got a Cleveland in mine but the steering is tight around the sump. Junked the drag links in favour of a rack now. Wheels are standard American fitting. Got 8x15 Cragars on the back of mine, had to cut the inner lip off the arches and put a rod from the chassis to the diff to stop them rubbing on traffic islands and tight bends.
    Jul 2009
    nottinghamshire
    725
    Hi if i fitted Cragars 7 x 15 on the rear would i have to cut the rear arches or would i be ok.Thanks
    Jul 2011
    West Mersea
    3,109
    55
    Big Joe is online now
    I have 7x14s rear and 6x14 front, they fit with no mods or rubbing
  1. ford zephyr mk3 418 XKN wanted
    By mygasser in forum Vehicles - WANTED
    Last Post: 16-07-2018, 23:22
  2. ford zephyr mk3 418 XKN wanted
    By mygasser in forum Chat
    Last Post: 16-07-2018, 23:15
  3. Replies: 15
    Last Post: 21-12-2014, 10:07
  4. Mk3 Zephyr Zodiac Gear Ratios?
    By FlatheadFordV8 in forum Tech Discussion
    Last Post: 23-05-2009, 16:02
  5. Looking for a Mk3 Zody or Zephyr
    By Munki Boi in forum Vehicles - WANTED
    Last Post: 30-04-2009, 15:30
